A Body Motor Mounts and Gen Ques.
I have read some of the threads on this swap (I particularly like Stealth71’s) but I still have some questions.
1. The 98 LS1 is usually listed by itself I was told this is due to the single bar map sensor so it has a slightly different harness. Is this true and are there any other differences?
2. I plan on using the factory engine harness; there any mods I need to do to the harness to make it work?
3. Does anyone know if you can get the BRP motor mounts separate from the whole conversion kit?
Thank you any help will be much appreciated
You can find a template of the early BRP (and S&P) plates and make your own, I used the template andsome 1/4" steel plate to make my own. it is not hard. You should talk to Phill at BRP to get as price on his new kits and parts..
If you get the GM LS1 conversion Guide, it will out line everything you need to know on the 98 engine/wiring and harness, as it was writen for the 98 engine and setup.
but like most of the other harness, you can make it a standalone harness but just adding the B+, ign 12+, ground and Fan wires to the connector.
my swap is in my sig..
I just bought their kit and it looks pretty good but I haven't started swapping yet. I am wondering about the e-brake line connection on the crossmember though as I see no provisions for it on their kit
http://carshop.carshopinc.com/produc...457/C/S%202370
http://carshop.carshopinc.com/produc.../86959/C/S2349
Next comes the pan, Some suggest using the lh8 pan and that's a great option but does come with a few negatives........
With my engine mounts I like to put the engine in as close to stock as possible keeping the driveline angles "stock". In this picture you will see that the LH8 pan fits, but with my mounts rubs on the top of the crossmember, this could easily be remedied by shimming the engine up about a quarter of a inch
However it clears nice, but hangs to low for my taste.... I like to lower my cars and do not like the idea of killing my car on a modest bump or pothole.
But I do like this pan, it is manufactured by champ and is the same as the ats pan...
Looks like you guys have lots of great options if I can help in anyway give me a call!
[IMG]
[/IMG]Look at the leathal notch I did in my s-10 to retain the factory F body pan! Scary Huh!
[IMG]
[/IMG] Thanks again everyone has been a ton of help.
