A-Body 6.0/5.3 Ford p/s pulley swap pics
#62
I just solved the pulley interference on my 64 chevelle using the 300-020 dorman pulley. I am installing a 5.3 in a 64 chevelle and have the grand cherokee steering box also. With the truck pulley it needed about 1/4 inch smaller pulley to have clearance. With the 300-020 pulley I now have about 1/4 clearance to the bolt head on the PS box. Also I am using the mast pan, so I probably have mine installed lower than most as the mast pan is very thin.
The next picture shows how much extra I had to push it on to get it to line up. This is the most it could go and still allow me to get the puller on it to remove it later if needed.
The pulley was $22 new shipped to my door from rockauto.
#63
Its steel at least:
Part Number:
300-010
Weight:
1.4 lbs
Warranty:
3 MO
Color/Finish:
Black
Installation Hardware Included:
None
Installation Instructions Included:
No
Material:
Steel
Package Contents:
Pulley
Remanufactured Part:
No
Pulley Diameter (in):
5.625
Pulley Type/Grooves:
Serpentine
Weight (Lbs):
1.43
Is that e-150 the right application?
#64
Bringing this back-up. The e-150 pulley search I did brings up Dorman 300-010 which looks like this:
Its steel at least:
Part Number:
300-010
Weight:
1.4 lbs
Warranty:
3 MO
Color/Finish:
Black
None
No
Material:
Steel
Package Contents:
Pulley
No
5.625
Serpentine
Weight (Lbs):
1.43
Its steel at least:
Part Number:
300-010
Weight:
1.4 lbs
Warranty:
3 MO
Color/Finish:
Black
None
No
Material:
Steel
Package Contents:
Pulley
No
5.625
Serpentine
Weight (Lbs):
1.43
#65
found another option today for a pulley to use with truck accesories.
http://dirtydingo.com/store/product_...oducts_id=1389
