LSx into 64-72 GM A-body
Old 03-15-2011, 12:33 AM
williamkeller23's Avatar
just a slightly off topic comment. i heard someone on this forum or a similar one say that ron davis radiators were twice the radiator as other brands. this is somewhat confusing considering it costs three times as much. the math doesnt add up. just my 2 cents
Old 03-17-2011, 04:19 PM
chevellechad's Avatar
Wow Great Stickie, I have a lot of reading to do!! At the 66 Chevelle, LS swap starting line
Old 04-07-2011, 08:37 PM
Old School Heavy
speedtigger's Avatar
Can you please add my swap to the Buick list please?
https://ls1tech.com/forums/conversio...ld-thread.html
Old 05-04-2011, 09:22 PM
((((((Administrator))))))
CRAGER's Avatar
Thumbs up
You got it!
Old 06-13-2011, 10:51 PM
Aceshigh's Avatar
They say that you should use the small block Chevy perches like you did, but you have to slot each side 1/2" for proper fit. So, I guess the Edelbrock instructions are accurate.
So you're saying we have to use a 1/2" spacer between the frame and the frame mounts to lift it up high enough ??
Where did you guys get your spacers cut ?? Local machine shop ??
Old 06-14-2011, 09:49 AM
Old School Heavy
I am not sure where you go the idea you need a spacer. The instructions say slot the crossmember bolt holes. It does not say anything about a spacer.
Old 06-27-2011, 06:10 PM
Aceshigh's Avatar
I misunderstood what "Slotted" meant.
Now I get it. Like this.
Old 06-27-2011, 06:19 PM
Old School Heavy
Thumbs up
That's it.
Old 11-22-2011, 07:33 PM
the450r's Avatar
My goat needs added
https://ls1tech.com/forums/conversio...-t56-swap.html
Old 04-22-2012, 07:23 AM
garys 68's Avatar
You can add my 72 Olds with a 5.3.
https://ls1tech.com/forums/conversio...442-build.html
Old 04-09-2013, 10:01 PM
mrblack454's Avatar
maybe someone here can help me.. 69 chevelle ls1 - t56 swap.. I have hooker adapter plates (standard location) and short/wide mounts (even though my engine was a 307--yes very strange) the trans is a brand new tremec t56 magnum. the dilemma im having is setting my driveline angle. most people on here are flipping their trans mounts, but mine without flipping it is exactly at 3 degrees (rocker panels at zero degrees) the issue is ill have to remove my floor brace and it doesn't seem like many people are doing so.. please help!!
Old 04-10-2013, 09:18 AM
  #32
Project GatTagO's Avatar
Received 1,451 Likes on 916 Posts
My build actually uses the Richmond 6 speed, not the TKO, in case anyone cares.
Andrew
Old 08-29-2014, 01:03 AM
  #33
6trs's Avatar
Default LS3 into 70 Monte Carlo
My build is here...
https://ls1tech.com/forums/18397060-post1483.html
Old 08-30-2014, 04:00 PM
  #34
the450r's Avatar
My build is here
Old 12-21-2015, 11:42 PM
  #35
sonnyd9's Avatar
Great Tips started my swap yesterday and putting a few of your tips to use - thanks
Old 02-16-2016, 05:30 AM
  #36
farmall's Avatar
Great info.
Old 02-16-2016, 08:52 AM
  #37
1964SS's Avatar
Can you please add my swap to the Chevelle list?
1964 Chevelle LS1-T56 swap
Old 10-17-2018, 08:17 PM
  #38
old66tiger's Avatar
Add my GTO to the list
https://ls1tech.com/forums/conversio...nvertible.html
Old 07-19-2022, 05:54 AM
  #39
82z28macdady's Avatar
https://ls1tech.com/forums/conversio...60e-build.html
raise from the dead!
Quick Reply: LSx into 64-72 GM A-body
