mustang ls1 swap parts list
Old 11-14-2008, 03:59 AM
  #41
95PGTTech's Avatar
Originally Posted by BAMF GT
Couldn't you just open up the hole for the clutch fork in the bellhousing and use a 03-04 Cobra clutch fork/Throwout bearing and keep the cable clutch setup? The boss should be on the transmission front cover for the pivot ball, just needing drilled and tapped. You could look into using an 03-04 Cobra yoke as they also came with T-56's and the output shaft should have the same spline count.
that's a question I've been wondering, posted a thread about it. I came to the conclusion that I'm going to have to buy an aftermarket bellhousing which does have the cutout for the fork even on the LS1 T56 bellhousings and the pivot ball provision
Old 11-14-2008, 05:02 AM
  #42
djquik88's Avatar
It's cheaper and easier to just keep the hyd. clutch setup. Check out my OLD build thread in my sig. Also,I just happen to have another Thunderbird tubo coupe clutch pedal assembly. PM me your email address and I will send you a few more pictures of my set-up.
With the aje k-member, my drive shaft was 44'' from cap center to cap center( caps on the shaft) Don't take my word for it though. Measure yours! Just go to any driveline shop and tell them what you are doing.
Mike
Old 11-14-2008, 07:29 AM
  #43
wheelies247's Avatar
djquik88
wheelies247@gmail.com
Old 11-15-2008, 09:53 AM
  #44
anyone know if theres any rubber motor mounts i can use ????
so i dont have to bolt up motor straight on to the k member really dont like the vibration im going to feel once its all running????
Old 11-15-2008, 02:12 PM
  #45
lt4malibu's Avatar
LS1Tech 20 Year Member
the AJE has poly bushings and its not that bad, the only way to use a "rubber" mount is with the 4.6K and modified mounts
Old 11-16-2008, 05:16 PM
  #46
does the car vibrate a lot without the bushings ???? on the motor mount
Old 11-16-2008, 09:38 PM
  #47
lt4malibu's Avatar
id classify it as marginal, the car has subframe connectors and a 6pt bar so its stiff anyway.
Old 11-16-2008, 10:32 PM
  #48
sweet thats
Old 09-29-2009, 03:40 PM
  #49
novanutcase's Avatar
I have an '03 GT. Is there any way to mount the motor on the 3650 5 speed?
John
Old 10-18-2009, 08:14 AM
  #50
BAMF GT's Avatar
I've asked around and even messaged Keisler and they said no dice. The 3650 Bellhousing is integrated into the case and would have to be cut off and a custom adapter plate made to begin with. However, What I'm thinking about doing is finding someone that wants to trade me thier T-45 straight across out of thier Mustang and then I can use Keisler's kit to adapt and LSX to that, keep my cable clutch which I like, all mounts and everything already works without modding.
Old 10-27-2009, 11:25 AM
  #51
Blue Coupe's Avatar
Will a 305/350 T5 bellhousing bolt up to an LS1?
Can I use a Ford T5Z with the chevy bellhousing?
Thanks
Old 10-28-2009, 12:26 PM
  #52
LittleRedZ's Avatar
ttt ttt
Old 02-02-2010, 02:47 PM
  #53
TipsyMcStagger's Avatar
Originally Posted by magic
Just the 4.6 motormounts to fit the LSx motor.
Also, depending on the oil pan used and if you are using the stock factory 4.6 K-member, you might need to notch the pan or K-member to clear the oil pan.
Here is a link to read on the motormounts:
http://www.lsxextreme.com/showpost.p...44&postcount=2
That link seems to be dead.
With a budget in mind, has anyone here recently used a factory 4.6 K-member for a Fox LSx swap?
Tipsy
Old 02-02-2010, 03:10 PM
  #54
Quoting myself but I just read the following post by LS1hatchback from another thread. Looks like the 4.6 K-member isn't a very good option for the LSx Fox swap:
Originally Posted by LS1hatchback
Problem with using the 4.6 k member is that you need to use the 96+ spindles to correct the bumpsteer. Using the modular spindles will make the front wheels stick out noticeably. Looks really shitty IMO unless you use rear SN95 axles which make using a large tire more difficult...
Tipsy
Old 02-02-2010, 03:41 PM
  #55
Spoolinsteve's Avatar
I am using the 4.6 K-member but the motor is yet to go into the car. Please be aware that if you use the iron block it does not have the same provisions for mounting as the aluminum motor.
It still can be done but it is not as simple as some write-ups make it. The third mount that you have to extend the factory 4.6 mount too is not present.
Old 02-02-2010, 04:32 PM
  #56
Dickie-311's Avatar
Default my list
engine , tranny and supporting parts only
engine 700.00
oil pan 240.00
gaskets / oil pump 240.00
heads 1480.00
cam+pushrods 425.00
lifters 125.00
retainers 29.00
ARP ROD bolts 87.00
timing chain 65.00
AJE motor mounts (chevy) 81.00
tranny (200r4) 1500.00
trans TV cable 60.00
PTC converter 470.00
flexplate 160.00
flex plate bolts 27.00
proform 750 carb 280.00
victor jr intake 200.00
A1000 fuel pump 190.00
MSD 6010 300.00
WIRES 65.00
head bolts 150.00
swap headers 600.00
thats $7400.00 just off the top of my head
theses are parts i still need
throttle bracket 80.00
throttle cable ( from 85 stang) 30.00
electric water pump 400.00
drive shaft guessing up to 300.00
rest of fuel system 700.00
starter 60.00
alternator 90.00
belt and hoses est 30.00-50.00
alt mounting 120.00
trans cross member and mount 200.00
shifter 180.00
trans cooler w/ fan 175.00
braided trans cooler lines and AN fittings est 125.00
and another $2500.00 to finish it
Old 02-02-2010, 05:06 PM
  #57
That's good info...hadn't read that before. I plan to use an LQ4, so a factory 4.6 K member seems even less of a good option.
Tipsy
Old 02-02-2010, 05:25 PM
  #58
Remember alot of people make the lsX k member/mounts now. Pa-racing and AJE just to name a few without stepping on any toes.
If you can fabricate simple mounts for various things, weld up an exhaust or anything along those lines I feel you should be able to tackle the 4.6 dilemma. I plan on writing up some info to contribute to the boards in the next coming weeks.
Old 02-02-2010, 08:54 PM
  #59
99MUSTANG5.3L's Avatar
I have an '01 Mustang that is a factory v6 that I am swapping in a 5.3l/4l60E. I am going to try and keep the factory k member. I do have the ability to do my own fab work, so I will keep updates as I proceed! Gonna be a couple weeks minimum because of the weather. I've been told the v6 k member will also work by someone who's already done it.
Old 04-10-2010, 08:01 PM
  #60
Did a test fit with the 5.3 and v6 crossmember,doesn't look like it's gonna fit with the truck manifold and stock hood.New dilema, buy AJE crossmember or buy LS1 intake and water pump?
Quick Reply: mustang ls1 swap parts list
