Syclone LQ4/4L80E tc78 build
Old 01-16-2009, 11:01 PM
  #241
Summerwolf's Avatar
Originally Posted by eviltwin_1987
but it seem as though you dont know **** about syclones
lol, okay....I may have never owned one but doesn't mean I haven't been around the block....
what are you doing with the stock motor/trans setup?
Old 01-16-2009, 11:05 PM
  #242
eviltwin_1987's Avatar
it will be up for sale if i ever get around to it
Old 01-16-2009, 11:07 PM
  #243
squee's Avatar
I may be interested in it. Let me know when you get ready to sell it.
Old 01-16-2009, 11:32 PM
  #244
ok. it will probably sometime next month
Old 01-17-2009, 10:51 AM
  #245
Summerwolf's Avatar
how much you think you'll be asking? I have a couple projects that would benefit from that setup
Old 01-17-2009, 01:52 PM
  #246
probably around $3000-$3500 for everything i took off expect t-case.
Old 01-18-2009, 03:16 PM
  #247
extremetoy's Avatar
o cool.
Old 01-18-2009, 07:15 PM
  #248
here is the truck, just waiting on the turbo still , thanks to the great sponsor.
other than that its finished
Old 01-18-2009, 07:25 PM
  #249
will01's Avatar
looks sharp with black zo6 rims!
Old 01-18-2009, 07:48 PM
  #250
extremetoy's Avatar
Any info on that sick looking bronco in the background? How many ponies is she pushin?
Old 01-18-2009, 07:51 PM
  #251
crfdude86's Avatar
Ya I was wondering the same thing on the bronco too. That thang aint built ford tuff with chevy stuff is it?
Old 01-18-2009, 07:53 PM
  #252
MX221's Avatar
Ya I LOVE that color on that bronco. Want to paint my 69 camaro the same.
Old 01-19-2009, 06:50 AM
  #253
jfg455's Avatar
Best part is noone will see it coming! TY/SY are quick but I think this thing will surprise the hell outa someone!!
Old 01-19-2009, 10:21 PM
  #254
well the turbo came in so i did alittle work today.
will do the downpipe and intake tomorrow hopefully
Old 01-20-2009, 10:12 PM
  #255
finished the down pipe today. turbo is in there for good.
things left to do
1. bolt in wastegate, hookup vac line
2. turbo to intercooler pipe
3. hook up oil lines
4. tune
5. go to track
Old 01-20-2009, 10:13 PM
  #256
where an i going to route the intake pipe
Old 01-20-2009, 10:50 PM
  #257
Grr
Grr's Avatar
kinda backed your self into a corner there eh?
Any way to go down and across to below the drivers framerail?
I got it, go back and down the intake and cut a hole in the cowl. Put your filter in there it would be sweet
Old 01-20-2009, 11:15 PM
  #258
Verz's Avatar
i was wondering the same when i saw the pic before the downpipe, hope you get it figured out, cant wait to see it run.
Old 01-21-2009, 10:07 AM
  #259
68 TT's Avatar
Can you flip the orientation of the turbo 180 degrees so the intake is on the fender side? You will have to remake the down pipe connection pipe but it will allow you to pull cool air from behind the headlight.
It may make plumbing to the intercooler easier too as the outlet will be facing forward instead of towards the firewall.
My old 90 Chevy truck had an air cleaner assembly that pulled air from the fender cavity so it was isolated from the engine bay heat. Maybe that is an option to think about as well if you can not fit a cone filter on there. A fabricated air box sealing to the fender cavity frame where the down pipe connection tube is now with a flat filter element integrated into it may work.
The worst thing that happens is you slightly modify the header to shift the turbo a little one way or the other to make the turbo fit better in the flipped orientation.
Old 01-21-2009, 03:46 PM
  #260
MaxxMitchell's Avatar
wow, I have no idea how you can get the charge pipe back out. To build off running the charge pipe back along the intake, isnt too bad of an idea, if you change back to a air 2 water intcooler, then flip the intake manifold around.
Or rebuild the hotside so that the turbo is turned the other way. Hopefully being able to look at it in person, you can find a way.
Is it possible to have a tight 2.5" 90 welded onto the compressor outlet, and then turn it to where it can feed between the headlight and the exhaust side?
Can you weld on some bends to the compressor housing, and route the charge pipe between the rad/engine?
Quick Reply: Syclone LQ4/4L80E tc78 build
