F-Body LS1 to LS3 conversion
I've had a conversion project in mind for a while now and feel like pulling the trigger. That is, if their are no fundamental flaws in this mission. If so, I would sure like to know about them sooner- than later.
I want to swap out the LS1 in my 1999 Z28 Camaro 6spd. manual for a LS3 crate engine with: " GM "plug-&-play" harness w/ECU and "front accessories package".
Questions:
Are the any engine vs 1999 engine compartment clearance conflicts? Will the LS3 engine bolt right up to my 1999 stock 6spd. manual transmission?Tricks or solutions? For those of you who have done this F-Body ('98-'02) LS1 to LS3 swap already, or those who have seen it done, or know something first hand about doing it- I would really appreciate your input on this subject.
Thanks
You might "top the project off" with an LS6 intake manifold & a set of long-tube headers while you have it all out, but as far as the actual swap goes it should be little more than a basic R&R...
Good luck.
By the way the LS6 intake suggestion is not correct for this motor. It has the newer heads and the LS1 / LS6 intakes do not work on them. However the crate motor comes with the newer intake so you will be fine.
& was thinking about the motor in terms of a long-block, so the TB never even entered the picture for me...
One thing that neither one of us mentioned is that the LS3 almost certainly has a 58x reluctor wheel on the crank, which is different than the 24x on the original LS1s, so you'll have to account for that as well.
Good luck.
At this point, I'm keeping the LS1 computer. My shpping list for keeping the computer includes:
Katech Cam sensor and knock sensor harness
Lingenfelter's Reluctor Wheel conversion box (whenever it gets released)
And I'm looking into Pantera EFI's DBW to cable throttle body conversion package, so I can reuse the L92 TB (if its cheaper than out right purchase of a new TB).
I'll also be using the L92 / LS3 intake and fuel rails.
The engine hasn't arrived yet, so I'll figure out what else needs to be replaced or swapped when it gets here. I don't want to keep the VVT (and or DOD if it even has it) so keeping the LS1 PCM makes sense for me.
You might want to look into keeping the VVT. The L92 doesn't have displacement on demand but with a cam swap and the VVT and a tune you can get 530hp at the flywheel. Check out Mast Motorsports. I am using their computer, harness, tune, and cam on my L92 motor thats going in my Nissan 240SX. It really doesn't come out that much more when you have to do all the other stuff too.
Tim
Tim
Can we expect some super awesome group purchase price for the 1st batch!
I've been waiting for this project. I'm sure I am far from alone!
anyone else care to shed light on it or that have used it?
