Wiring a LS1 into a LT1 Car
My swap, 99-02 A4 harness to 95 A4 LT1 (bare bones, no emissions or a/c):
Re-pinned LS1 harness for swap to LT1
C100
A Same pnk- pwr feed from injector fuse #9 Bank 1 (2,3,5,8)
B C101 B pnk- pwr feed from injector fuse #10 Bank 2 (1,4,6,7) (moved from c105 B for simplicity)
C
D C101 G orn- pwr feed from PCM fuse #8 to PCM
E c230 K dk grn serial data signal (moved from c105 E for simplicity, was tan on LT1)
F
G Same pwr feed from ignition fuse #11 (4L60E)
H Same dk blu coolant fan 2 & 3
J Same dk grn coolant fan 1
K
C105
A
B moved to c100
C
D
E moved to c100
F
G
H
C210 (LS1 Does not have this connector)
A Purple wire to starter solenoid
B C230 G Grey fuel pump ground (was blk on LT1)
C
D
C220 White
A generator feed to gauge cluster (spliced into alt wire for voltmeter)
B C220 A tan Oil pressure feed to gauge cluster
C (oil level was eliminated)
D
E
F
G C220 K dk grn/wht vehicle speed signal
H
J C101 D dk grn/wht fuel pump relay control
K Run extra wire off 1998 coolant temp sender
C230 Blue
A
B Same MIL/service engine soon indicator
C
D C105 G wht tach signal
E (unnecessary if VATS is disabled)
F
G C101 E pnk Power to PCM, on LT1 - feed from PCM ignition fuse #5
H C220 D ppl TCC/cruise brake switch
J C220 H PNP switch signal, on LT1 - Park/Neutral feed from trans position switch
K
C100
C
F
K
C105
A
B moved to c100
C
D
E moved to c100
F
G
H
C
D
C220 White
D
E
F
H
C230 Blue
A
C
F
K
If it's over complicated then find the simpler source..lol
There is a shitload of technical info here that many have used and got their stuff working..
I know for a fact Fuse #11 in the LS1 powers the Coils..that was in the LS1 All Data..so that is how I wired it up.
Bare with me since I dont have my diagrams, but that is what I remember.
Edit:In the LS1 Harness All Data Diagram, Fuse 11, the IGN Fuse, powers the PCM IGNITION, which goes from the Fuse Box to the Connector, then directly to PCM BLUE #19. I edited this and updated it, I looked at a schematic and verified it. I apologize for the confusion.
Confirmed by shbox and Chilton repair manual that fuse #11 is pwr to 4L60e on the LT1.
After studying the diagrams for the 1995. It looks like the MAF gets a signal from c230 G "power feed from PCM ignition fuse #5", also "PCM ignition pwr". It looks like the o2s get signal from c100 F "pwr feed from fans/actuators fuse #6".
So, It looks like I need to take one of the two pink wires (from LS1 harness c105 and c220 for MAF and o2s) and splice it into c230 along side "PCM ignition pwr" and take the other pink pwr wire and run it to c100 F??
Any input?
Any input?
What you need to do it break down the LS1 Harness and figure out what you actually need to power, then find your power sources in the LT1 circuits.
This is all of mine for the Engine..I have one C100 Connector on the Wheel Well with 8 wires total, all of them go to the Fuse Box. The first 6 are circuits that needed power, if I remember right there were only 5 Fused power circuits on my car so I found it easier to make an extra..basically I did a little re-wiring.
C-100 Connector:
PCM BATTERY
PCM IGNITION
INJECTOR BANK 1
INJECTOR BANK 2
MAF/O2's
TRANSMISSON
FAN RELAY CONTROL-LOW
FAN RELAY CONTROL-HIGH
So how do i know witch is c210-c100 ect? Im getting ready to swap a ls1 in my 95 t/a starting to take the lt1 out. I understand what to do but where can i get what pin connectors are what? Unless one of you wanna do my harness for me lol jk
would a truck harness work for this swap also i have a spare computer out of my truck i could get reflashed.
i was originally going to put a lt1 into a v6 body but i picked up a lq4 the other day fairly cheap. i was going to sell all the lt1 stuff to do the swap.is there any difference in the v6 underhood connections?
-thanks
-thanks
#34
100E on the LS1 harness tps signal. What happens with it? We are running a victor jr and accufab spped density. MAF and rear O2s tuned out but if that goes to tps what do I do with it and it it goes nowhere what will happen if its not hooked up?
#36
Not trying to thread jack here but figured since this is a lt1/ls1 post... Is there anyway to use the lt1 maf sensor on an ls swap? The maf plug on the ls harness is 5pin and the lt1 uses a 3pin maf plug. I'm just wondering if theres an aftermarket adapter of some sort.
#37
The following users liked this post:
snipescastle2 (04-24-2020)
#39
ok double checked the plug on C100 Pin E on the LS1 harness, it is dark blue and says its for TPS signal. it comes off the plug and tees into another wire that goes to Blue pin 24 on ECM and then to a plug. so any ideas?
second question...
C100
C
the wires that came from 105 B and E pins just get spliced in together with these wires so there will be two wires going to one pin? just wanna make sure im understanding this right.
second question...
C100
C
#40
second question...
C100
C
second question...
C100
C
I wired it in without an adapter..the wires are the same color. The 3 go to the MAF, the 2 from the AIT Sensor go directly to it..mine works like a charm.
