LS1 plugs and connectors. Need help identifying
Old Nov 17, 2008 | 11:06 AM
screaminChick-n's Avatar
Default LS1 plugs and connectors. Need help identifying
I never worked on a LS1 car before. So got this salvage car.....so now trying to identify a few wires. plugs etc so I can mark them up so hopefully the swap would go smooth. Any help appriciated
Old Nov 17, 2008 | 12:02 PM
bczee's Avatar
first of all, what car/year did this come from ?
1st Picture and item is the EVAP purge valve, part for SMOG, can get rid of it as the rest of the smog tubes if not requires. Red tube and stuff are for the AIR injector system (?) and part of the SMOG.
2nd picture, 1st item is the Knock Sensor connector, MAP sensor, Cam sensor and Oil sender starting in the upper left and going clockwise.
Not sure on the 3rd one.. sorry Could be outside air temp ?
Old Nov 17, 2008 | 03:34 PM
Thanks bczee for the quick response.
This LS1 is out of a 2002 Trans Am.
About the 2nd picture...If u look closley. the Knock Sensor connector, MAP sensor, Cam sensor are somhow linked to the a big round composite plug which is part of the intake. And as you can see there is also a rubber tube that is part of the Smog system attached to it. I have remarked the thing I am trying to pint ut in blue above
Can I take of all the smog tubes and cap the ports with some rubber caps or EVAP caps for the local auto store?
Old Nov 17, 2008 | 09:54 PM
bczee's Avatar
Yes... you can either by some pre-made plates for the Air and EGR ports on the Exhaust manifold or build your own. I would consider keeping the PCV system or some of it.. as having vacuum in the crank case is a good thing, but having a good PCV or Catch Can will help control the oil being sucked into the intake.
The EVAP can just be capped by a rubber cap or us it for some other device that requires a vacuum source.. I used it for my Charcoal Canister.
The 2nd picture w/blue marking. .is the vacuum port for the a) Brake Booster (large hose going to the left in the picture), b) MAP sensor and c) the EVAC / Heating control system that requires vacuum to operate the valves and door in the heating/AC system. Do not try to remove the plug as I have not found anyone that was found a OEM replacement part for that plug.
I have a 99' LS1 and the Air and EGR are different from your 02' system. If not required, remove all of the SMOG equipement with the exception of the PCV system, it has some value if not a total all out race engine. But remember that your Fuel tank must either be purged or vented.
Old Nov 18, 2008 | 03:10 AM
Cool......make some sence now.....
I want to keep the PCV system........How do I identify and seperate that from the SMOG and EVAP system ?
I can post some unmarked pic if that will be easy for you to mark on.
And I really appriciate the info you have been providing
Old Nov 18, 2008 | 12:33 PM
bczee's Avatar
on the 2nd pic.. the hose on the top that has a Y, is your pcv hose and system.
As far as the 1st picture with the Red lines, my 99' didn't have that setup, but my guess would be the dump that setup.. Air/EGY system. but if someone with the correct year ping in and let us know what those hose and setup is for.
Old Nov 19, 2008 | 10:58 AM
the_merv's Avatar
Veteran: Air Force
It looks like something to do with the EGR..from what I have seen it was done differently them years.
Old Nov 19, 2008 | 11:25 AM
wait4me's Avatar
The 2002 does not have EGR.,
Old Nov 19, 2008 | 11:46 AM
the_merv's Avatar
Veteran: Air Force
That's what I figured, but look at that setup.. it's either putting normal Air into the Exhaust that's going through them Hoses, or puttin some Exhaust into the Intake..
Old Nov 19, 2008 | 11:49 AM
wait4me's Avatar
That is the AIR system. secondary air injection for the Cats.
Old Nov 19, 2008 | 11:50 AM
wait4me's Avatar
That pic you have near the radiator is probably the windshield washer fluid pump.
Old Nov 19, 2008 | 11:55 AM
the_merv's Avatar
Veteran: Air Force
Yea that's the Fluid Washer Pump.
Old Nov 24, 2008 | 11:13 AM
Lol........all this time I thought it was something important .....
I got the whole harness out......I missed a few wires ........but I will deal with that later.
On the passenger side , below the starter Big round plug going into oil pan , I think..
What would that be ?
Old Nov 24, 2008 | 11:30 AM
the_merv's Avatar
Veteran: Air Force
Oil Level Sensor..lets you know if the Car has low Oil.
