Serpentine Systems - Vet vs F-body vs Truck?
does anyone have a link or can post up some diagrams showing the difference between the serpentine systems of the Vet, F-body, and Truck. Including the offsets (apparently they are all different, from what i've gathered?)
trying to figure out what system if any will work for my swap/configuration.
thanks.
thanks.
"truck" engines...
![](http://img155.imageshack.us/img155/4338/092053l20v820lmg20slv20tb3.jpg)
Corvette LS3 (pretty sure all vettes other than ZR1 are the same)
![](http://img211.imageshack.us/img211/3189/092062l20v820ls320cor20sn5.jpg)
98 to 2002 F-Body
![](http://img361.imageshack.us/img361/5610/image006lw3.jpg)
I would stay away from the F-body stuff purely out of serviceability concerns. Alternators are a somewhat regular service item and they are a total pain in the ***** to get to (obviously).
98 to 2002 F-Body
Do you know what the offset difference is between the three?
i'm swapping in a 5.3(truck) motor so that is what i have. but, i have a feeling i'm going to be making my own brackets AGAIN, because i need my custom 200amp alternator (which is gigantic in size compared to stock) to be mounted where the F-body one is. it's on a tubed offroad vehicle so accessing it isn't an issue.
those are great pictures, thanks!
as measured from the flat on the timing cover to the back rim of the pulley: a corvette pulley is 0.6", f-bodies and GTOs are 1.0", and trucks and SUVs are 2.5". ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
keep in mind the back belt on all 3 are the narrow groove for the AC compressor, so the actual accessory belt will be another 3/4" or so farther out.
thanks 1BadAction! that is the info i was looking for.
i think i can spare the longer truck setup, put i can see if you are trying to fit 10lbs in a 5lb can the Vet system may be worth converting to.
thanks again.
thanks again.
one more thing,
so are the water pumps different for all three systems? i see differences in water neck inlet/outlets, but are they different lengths, like old school long/short small chevy pumps, or is it just the pulley offset that is on each one?
2002, alternator, bodies, body, difference, fbody, offset, pulley, serpentine, serpintine, set, stay, system, truck, veterinarian
