Miro's LS1 240 Drift Build
Old 02-07-2009, 03:16 PM
  #141
UsJdmtuner's Avatar
thats a sweet video....so you are going to do your bodywork? u painting also?
Old 02-07-2009, 03:17 PM
  #142
UsJdmtuner's Avatar
Originally Posted by StanBo
Thanks for giving me something cool to read today. I read this all on a tiny sidekick screen and joined so I could post up.
Can't wait to see this done and running and also start my build.
Stan we have to catch up with this guy!!!
Old 02-07-2009, 03:51 PM
  #143
98camaro28's Avatar
Y'all are some crazy MFers! NICE WORK!!! CAN'T WAIT TO SEE THE FINAL PRODUCT!
Old 02-07-2009, 10:31 PM
  #144
miro's Avatar
Yep. Not much body work to do, just some dings on the rear quarter panels and smooth out where I welded some rust holes. All other panels are brand new fiberglass anyway... haha.
Old 02-09-2009, 04:26 PM
  #145
Bling's Avatar
just went through the whole thread. WOW, you must love fabrication work. and holy huge door bars, those would survive a big rig running into your door i bet haha.
Old 02-09-2009, 05:10 PM
  #146
miro's Avatar
I was planning for a high-speed train.
Old 02-09-2009, 05:22 PM
  #147
Santorican's Avatar
Wow this is an awesome build. I can't wait to see it when it is done!
Good luck!
Old 02-10-2009, 06:18 PM
  #148
RUTH'LESSDET's Avatar
wow the scene looks pretty good out in NJ when i get my alignment done over im gonna take a trip out to one of the nj meets
Old 02-11-2009, 11:33 AM
  #149
StanBo's Avatar
I am still builing up the shop. Mine is going to be one off to the extreme. Can't friggen wait. Working OT like a **** to make it happen.
Miro I will PM you on the chassis it is going into. I want to keep it under wraps.
Old 02-16-2009, 11:52 PM
  #150
miro's Avatar
A few more minor things done:
Pulled the fenders. The pic above is with a 17x9 -5 with 225/45 tire. It fits with plenty of room; should be perfect with 18s and a bit less camber.
Hydraulic e-brake kit came in via Slidewayz.
Picked up some brand new 225/40R18 Dunlop DZ101s for a good price. I'll mount these on 18x9.5 practice wheels, which are coming soon.
Drilled inspection holes in each required bar in the cage. These are mandated so that the thickness of the tubing can be checked.
Made a new battery mount. I drilled holes in the floor and welded nuts underneath the car to receive four bolts. The battery mount is the same thing I had before but made out of steel instead of aluminum.
Cut the dash bar in 50 places and finally got it to fit in the car.
I cut the ends off the dashboard so that it would fit in the car with the cage. Forgot to take a finished picture.
Welded in the base for the hydraulic e-brake on the transmission tunnel.
Made brackets for the Accusump on the transmission tunnel so that I can see the gauge from where I'm sitting. It's angled up in the rear to allow any air in the oil to travel up and escape through the line instead of getting trapped in the cylinder.
Made a bracket for the CM remote filter.
It's important to be comfortable while you're welding.
So the car didn't get painted this weekend as planned, but paint and all supplies will be in my hand tomorrow. There's still a lot of prep work to do, but it will DEFINITELY be painted next weekend. At least all welding is officially done.
Old 02-17-2009, 12:58 AM
  #151
eviltwin_1987's Avatar
i could never understand why people run such skinny tires on a wide wheel. why is that?
Old 02-17-2009, 03:02 AM
  #152
frojoe's Avatar
Apparently with skinny stretched tires and higher pressures = very little sidewall flex = easy to initiate slides? Also some go for the ridiculous uber-wide rim on way-too-skinny rim to get that look of the INSANE stretched tire... never really understood that style :S?!!!??!?!
Old 02-17-2009, 06:48 AM
  #153
miro's Avatar
Yep, the car should feel a little more snappy with a lot of stretch, but it's not a huge difference.
The reason why I want the tires stretched is because you can use a really low offset wheel (which looks awesome) and still get the tire to tuck into the fender with no rubbing. Stretching angles the sidewall so the tire tucks in easier.
Old 02-17-2009, 08:30 AM
  #154
themachasy's Avatar
Awesome build! Love the new progress. Keep it comin!
Old 02-17-2009, 09:48 AM
  #155
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Lookin good!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 02-17-2009, 09:54 AM
  #156
dark_dementshun's Avatar
Did you use an Eastwood, or how did you roll and pull your fenders? It is coming together nicely!
Old 02-17-2009, 10:36 AM
  #157
miro's Avatar
I used a propane torch and Eastwood roller borrowed from Slidewayz. What would I do without these dudes?
Old 02-17-2009, 09:21 PM
  #158
Bdizzle's Avatar
how'd you figure out the bends for your cage
Old 02-18-2009, 10:10 AM
  #159
miro's Avatar
I'm not sure what you mean. I measured the interior and based the cage dimensions off that. Exact dimensions depend on what kind of cage you want and how much clearance you want between the cage and the body.
Some parts of the cage can be done just by trial and error. For example, to make the door bars curve outward,
I bent the ends of a bar to 8 degrees or something, then mocked it up in the car, then bent some more, mocked it up, etc. Once I was happy with that one bar, I made the rest of the door bars to about the same dimensions.
I made the main hoop just measuring the widths and angles (50" base, 39" at the top, 68 degree top bends, 22 degree side bends). I used a longer tube than necessary, then trimmed it once all the bends were done to get the height of the hoop right.
Anyway, hope this answers your question.
Old 02-18-2009, 02:56 PM
  #160
greendrazil's Avatar
Love the work and care you've put into the car.
Quick Reply: Miro's LS1 240 Drift Build
