LQ4 in a 1971 Nova
Iron 370 cid
10.5 scr
L92 heads milled .020"
LG motorsports G6x3 cam (235/245, .645/.610, 111(?))
LS3 intake
Holley 90mm TB
American Racing 1 7/8" headers with 3" Pypes exhaust
4L80e w/ Vig 3600 stall and HD2 shift kit
~3200 lb car w/o me
3.90 gears
255/60-15 MT ET Streets
Springs, pushrods need to be updated for that cam and rpm with that big intake valve. Need a 155/400 double spring and thick wall (0.100+) pushrods.
And geometry setup correctly.
And your intake doesn't help, but the long runner is why all the LSx motors peak around 6300 or go flat. Stock Fast 102's flow considerably less than those heads will. And not everybody can port them well despite how easy it looks.
Nice build btw, yours along with bandit and fro keep me motivated on mine.
I've been reading up on ladder bar suspensions, and I've got a few things to try next time out.
Man, and I can get Garretts for cheap...
You know what I find interesting? LG Motorsports's dyno results. Here they put down 493/440 on a 2008 C6 with only a CAI, headers, and G6X3 cam. And here's a cam-only C6 that put down 462/430. Both are 6-speeds, but the discrepancy with my numbers is staggering.
Anyway, I'm uploading videos of my runs as we speak. I'll post them shortly. At least they look good with the gopro.
http://www.youtube.com/watch?v=fnQRy1xKMmM
http://www.youtube.com/watch?v=fdIEV...ature=youtu.be
http://www.youtube.com/watch?v=KsKrP...ature=youtu.be
Edit: according to this calculator, with Mahle L92/LS3 4cc relief pistons, 66 cc chambers, and a 4.060" bore, .051" gasket on a 4.030" engine bore, I'm at about 10.45:1. Piston deck height was checked on a few slugs during pre-assembly, and they were .005" out of the hole.
