turbo LQ4 4L80E mustang build
Why the Ebay intercooler? A friend of mine tested one and found it would be a restriction at anything over 6-700hp. Guys are using them with more then that but may be leaving power on the table.
Thought I would update this thread. I haven't worked on the car for 3 months, but got a chance to work on it today. I started out by working on the down pipe. I fished it through the passenger side control arm and k member. As of right now it dumps right by the trans.
![](http://img13.imageshack.us/img13/9687/c8f062ffcda512620109600.th.jpg)
![](http://img10.imageshack.us/img10/3778/dbfa6632571912620111700.th.jpg)
I also started on mounting my double pass radiator.
![](http://img9.imageshack.us/img9/1086/8907af072beb12620112850.th.jpg)
![](http://img13.imageshack.us/img13/3745/f616799a1c3c12620114080.th.jpg)
Tomorrow I work on the fuel system. I'm gonna run dual bosch 044's and an aeromotive fuel regulator.
![](http://img684.imageshack.us/img684/3738/87c6e975290f12620115610.th.jpg)
![](http://img684.imageshack.us/img684/8650/919ebf998f4012620114870.th.jpg)
Started cleaning up the passenger side inner fender apron. I made a template out of cardboard, then transfered to some sheet metal.
![](http://img37.imageshack.us/img37/5475/13d9b5ad26dd12620984200.th.jpg)
![](http://img693.imageshack.us/img693/6153/ccf8f5b0ed2d12620985200.th.jpg)
I have it tacked into place for now. I'll add filler and paint later on.
I also got the intercooler mounted
![](http://img9.imageshack.us/img9/7736/e4cff4eb53df12620986050.th.jpg)
Started on some fuel plumbing
![](http://img706.imageshack.us/img706/5403/a690b8c6318012620987050.th.jpg)
some cold side plumbing
![](http://img710.imageshack.us/img710/6904/c5979b232f6f12620988100.th.jpg)
More to come. waiting on some fuel fittings. I'll have to get a starter so I can finish my downpipe.
After mounting up the starter, I realized my downpipe wouldn't fit between the starter and the firewall. I tried going through the wheel well, but didn't have enough clearance from the tire. The only other way i could think was to go under the kmember. i tucked it up to the frame as close as i could. here it is all welded up.(sorry for the sloppy welds)
![](http://img695.imageshack.us/img695/2914/f96656aa068d12682421790.th.jpg)
plans are to spray it with some bbq paint and wrapping it with exhaust wrap.
I also redid the motor mounts to clean things up and gain some hood clearance. I cut the flanges off my solid 4.6 mounts and welded them to some 1/4" flat stock.
![](http://img694.imageshack.us/img694/7888/motormount2.th.jpg)
![](http://img19.imageshack.us/img19/2301/motormountf.th.jpg)
#35
what did you do for a trans dipstick? i tried getting the lokar th400 flexible stainless one to work, but it doesnt, i ended up grinding it down to the point that it broke before itd even come remotely close to fitting
#39
Painted the crossover and downpipe with some bbq paint. Wrapped them with some header wrap and threw on a couple more coats of bbq paint.
![](http://img541.imageshack.us/img541/6084/43f8c38c73f512739272400.th.jpg)
Got the radiator mounted
![](http://img442.imageshack.us/img442/1985/753520a4dce112739273480.th.jpg)
'04 ls6 cam and springs installed. Drill and tapped timing cover for the turbo oil drain.
Lastly, Wired and installed a Camaro instrument cluster. Lets just say if I ever wanna go back to stock, I'll have to get a new dash.
Shes coming together. Hoping to have it done in time for the Car craft summer nats.
![](http://img210.imageshack.us/img210/4329/fec2f4da5ac512739273870.th.jpg)
![](http://img34.imageshack.us/img34/6704/d1c567cfbd4612739273100.th.jpg)
