turbo LQ4 4L80E mustang build
#42
You mentioned that the trans fit with no problems earlier in the thread. What engine adapter plates did you use? How precise did you go with your measurements and angles? Mainly engine/trans centerline in relation to pinion centerline (How much if any ofset in height was there)? Also Pinion angle in relation to trans output shaft angle?
