LS powered Miata swap- Build Thread
Glad you got the turbo back on your Integra. Now take it out to the track!!!
As far as the fittings go, you have basically 3 choices... maybe 2.
You can use a Tube Sleeve and nut combined with a 37 degree flare
You can use a weld fitting
Or you can use a compression fitting.
There is a good discussion on compression fittings here:
http://forums.hybridz.org/showthread.php?p=923875
If the hard line your trying to adapt to is metric, your probabaly best off with the weld fitting or the compression fitting as I doubt you'll find a tube nut/sleve the correct size for the flare fitting... although if you get creative, you might make it work.
Swagelock is the only manufacturer of the compression fittings that I've dealt with. They sell metric tube to NPT fittings. There are other less expensive brands of compression fittings (such as parker) out there but I dont know if they carry the metric tube version.
Swagelok 10mm to 3/8"NPT
http://www.swagelok.com/search/produ...rt=SS-10M0-7-6
8mm to 3/8"NPT
http://www.swagelok.com/search/produ...art=SS-8M0-1-6
and use with this to convert from pipe to the AN fitting your hose will attach to:
http://store.summitracing.com/partde...5&autoview=sku
Dan W- Thank you! That is exactly what i was looking for.
Russell fittings:
filter supply p# 640853)
filter return to tank p# 640863)
Then just use a -6 AN compression fitting to attach to the fuel line.
Frank
fmowry- Thank you also for the links. I need to measure and see what size lines are coming out of my tank so i can get some fittings. Those actually look like what i had in mind until i switch to a twin intank setup with weld fittings.
Here are some last minute photos i took this morning before heading off to work. I put the fenders back on, and threw the front bumper on to get it off the ground. Also i managed to smooth out the new throttle body I got, and spray it black.
Whats the blue miata in the background?
I was on that one until seeing that he removed the suspension & re-installed the stock coilovers. Made me wonder what else may have been borrowed from the car, prior to selling. He did explain why the aftermarket coilovers were removed, but I just didn't feel good about it. Glad to see that it sold & for decent money.
LS1-450 - He had the exact suspension setup that i was wanting. We swapped over his roll bar, steering wheel with extension, and suspension to my car in place of my stock parts. He wouldn't have been able to get that much more for the car with all that on there. I made him an offer on it all, and he agreed to it. The suspension is pretty stiff, the roll bar had door bars making it hard for some people to get in and out of the car, and the extension on the steering wheel would have only cramped some people in even more. Me being a small guy (5' 7" 130lbs) and having ridden in his car, i knew it was the way i wanted to set up my car anyways. For how much he has invested in the car, whoever buys it can replace those "missing" pieces and make the car handle and feel the way they want while still coming out ahead.
These prices are including shipping, which adds up to a lot.
1990 Miata with Rota Slipstreams (blown motor) - $1000
2004 LS1 with 22k miles - 2600
Mildly built T56 with 4k miles since rebuild - 2000
LS7 Clutch kit - 500
Boss Frog subframe, trans mounting, etc - 1700
Used crappy racing seats - 40
Modified Shorty Headers - 500
Wiring harness - 275
LS2 Corvette oil pan - 200
Used HardDog Ace roll bar with door bars - 400
Used Momo steering wheel with extension - 250
Used suspension - 1100
Earls fuel lines and fittings - 475
Nasty fuel rails and inline filter - 300
Aeromotive A1000 regulator - 100
Grand total so far - $11,440
Things left to buy:
rear diff with Detroit True-Trac - 750
Boss Frog stage 3 axles - 2200
Driveshaft - 500
Boss Frog diff mount - 400
Brings everything up to $15,290
A couple of those I rounded over just to compensate for the little odds and ends that you need along the way. You won't believe how many trips to the hardware store i have made. Obviously you could save money on the engine and tranny. If i had to go back, i would have tried harder to find a whole pullout with low mileage. I think i would have come out ahead a decent bit. I hate adding it all up like this. You don't realize how fast it adds up. It should be worth it in the end though!
What springs did he have, front & rear ratings & length?
Just figured out last night that i didn't put the throwout bearing in the transmission. Gotta drop everything back down again. I'm going to go ahead and replace the slave cylinder while i am in there, and clean up some wire routing as well as secure the fuel lines in the transmission tunnel a little better. I'm sure i could have everything apart and back together in a weekend. Just one more setback though.
