LS powered Miata swap- Build Thread
BTW, I'm still messing around with the suspension after 5 years. Am in the process of yet another spring rate change in an effort to find more road course speed. Always, a work in progress.
Looks good! Cranks but no fire? have 58psi fuel pressure? Power to the coils? Power to the PCM? Can you plug a scan tool into the PCM?
Any ideas? I'm about stumped now. haha
can you hear the fuel pump kick in? and getting enough pressure?
if it's not getting sprak I'd have to agree with above, crank sensor is a likley cause
Is the ECU programed for the right crank reluctor wheel? iee 58x vs 24x? I assume it's 24x, but you never know
Crank sensor is what it's sounding like. It is a 2004 LS1 with a black crank sensor plug. All that spells that it should be a 24x wheel. Hopefully i will know for sure when i hook up a scan tool.
Odd that there are no codes such as neutral switch, clutch switch, air pump related stuff. What's turned off in the PCM?
I just posted this up in hopes of someone magically having the answer. All the wiring seems to correspond with my diagrams, and was not altered from its original position in the harness. I have no clue what all was turned off in my PCM. I called the guy at Wait4Me since they put the base tune on it, but he said he didn't have time to help diagnose. Understandable i guess.
Still no spark.
I just told him have a nice day and went with brian at PCMforless.
I didn't see any mention of this though. On the fuel part when you turn the key on but not start the car. Can you hear the fuel pump prime? If not something to look at there maybe a bad relay or something.
As far as no spark I'd be interested in seeing what was done on the tune. If you can get a look at it or have some pull it and post it up that would help...
Tails
Good deal eh?
My money is still on the crank/cam angle sensors. A tune won't effect start up, unless VATS has not been deleted
