crankshaft pulley for carbed LS1
Looking for the part # for the special crank pulley that is used for a carbed LS1 that has front mounted dist.with the GM timing cover,there was a guy on here with an LS1 Mustang who gave out the Summit # but i can't find it now,pulley is small in diameter so it can clear the bottom of the funky shape of the timing cover.any help would be great so i can order one.
best bet is too contact sponsor SDPC--->
they will have all th info u need related to that cover, if im not mistaken u have to drill the crank snout and pin it to locate distributor timing reference and it uses a "spud" deal, and uses sbf dist. also but i dont remember, it was too much hassle imo.
i think the msd box is more practical
carb kit
heres an old article but it doesn't have all the part numbers stewart components make the water pump for it so they probably know http://www.stewartcomponents.com/
http://www.chevyhiperformance.com/te...ase/index.html
try this guy, thats who aparnt. does a bunch of setups for the Bush guys
http://s41657.sites80.storefront-hos...m/default.aspx
I'm the guy that is using the Distibutor setup on the Mustang. The part I'm using is a balancer/pulley combo made from summit part # C2502 should be located here
http://store.summitracing.com/partde...5&autoview=sku
that is the one I bought and installed on my car
Here is the older blog with the pictures you are wanting.
http://www.mylrs.com/blogs/lrs/archi...ng-part-2.aspx
The Balancer has a provision for a keyway but to make things easy for me I'm just going to drill and stake it like you would do for a supercharged application.
