LS2 Serpentine belt setup with ProCharger ?
Hello,
we are currently building an LS2 engine with a serpentine belt kit from Vintage Air into a new project car. Now my question is - is it still possible to mount and run a ProCharger Kit on the LS2?
Thanks you very much for your ideas how it can be done ...
![](http://www.vintageair.com/08/images/FrontRunner/lsseriesLG.jpg)
a lot depends on the body style its going in, how much room-the vette setup uses a procharger mounted in rev, with the pulley inward, which is what i use on my chevelle, and the camero mounts i believe like in the normal direction
so you have 2 diff choices of mtg. and rotation to play with
the a/c compressor wont be able to stay where it is with the vette setup. you have to have vette pulleys also if your going that route. im running the the vette bracket also, with fbody pulleys. it took some rigging to make it work.
