G-body swap guys: Which radiator?
Yeah here's a pic with the transmission cooler lines going to it, I've been searching around and it seems most g-body radiators you get from the parts store will have that port, and it looks like people may be using it for a coolant level switch.
![Name: radiatorport2_zps32a36da5.jpg
Size: 58.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/610445d1501328218-g-body-swap-guys-radiator-radiatorport2_zps32a36da5.jpg)
And here's a picture of the plug that goes in the hole, maybe I can take the plug to a hardware store and check the plumbing section to see what fits that plug and that will tell me what size it is.
![Name: radiatorport3_zps0c7252b8.jpg
Size: 73.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/610446d1501328218-g-body-swap-guys-radiator-radiatorport3_zps0c7252b8.jpg)
![](http://i180.photobucket.com/albums/x177/dynodanmanda79/radiatorport2_zps32a36da5.jpg)
![](http://i180.photobucket.com/albums/x177/dynodanmanda79/radiatorport3_zps0c7252b8.jpg)
I'll be going with silverado upper and lower hoses, and i'll be going with an electric fan setup from a late 90's dodge intrepid. Most g-body guys i've seen that swap to electric fans either use the intrepid fans or a single fan from a ford taurus.
![Name: radiator5_zps45a158df.jpg
Size: 71.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/610431d1501328178-g-body-swap-guys-radiator-radiator5_zps45a158df.jpg)
![Name: radiator6_zps77f57c44.jpg
Size: 75.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/610432d1501328178-g-body-swap-guys-radiator-radiator6_zps77f57c44.jpg)
MalibuRacing, why do you need to run a temp probe? Although factory 99-04/05 trucks didn't come with electric fans stock, you can program a signal into the factory DBC PCM to have cts parameter set to turn on signal in pcm, so the cts effectively controls the fan.
I'm running a factory copper replacement from Advance Auto and it cools well, runs around 190 all the time even in the summer. Running a clutch fan with an electric fan "emergency" pusher.
I put a radiator made from superior radiator in mt Clemens mi.
$300 for the radiator $200 for dual electric fans and shroud.
$500 total. Inlet and outlet tubes on the passenger side. Radiator also has a trans cooler
The following users liked this post:
Brandons81cutty (01-22-2020)
