LS2 for '88 IROC-Z
Old Jan 8, 2009 | 10:45 PM
jj83's Avatar
Arrow LS2 for '88 IROC-Z
I'm just trying to find out how i can use the stock 3rd gen camaro gauges with a LS2/T56 swap. Has anybody done this? If so, how did you do it. From what i understand the ECM send a digital signal to the fuel level gauge. Is there a way to convert it? What about the rest of the gauges?
Old Jan 9, 2009 | 09:42 AM
Jaysz28's Avatar
Active Streak: 30 Days
PCM doesn't send a signal for the fuel level....
your Oil, temp and volts will work just fine.
Tach can work with some setting changed in the PCM
Speedo on your car is an issue though, since it is cable driven. You will need a converter box. Check Hawks thirdgen for an adapter that'll get it working
good luck
-jason
Old Jan 10, 2009 | 06:32 AM
HDon22s's Avatar
I drilled and tapped pass. head for temp & "t" in stock pressure sending unit.
Old Jan 10, 2009 | 03:02 PM
adrian87camaro's Avatar
do a search on thirdgen.org they have tons of info on how to get the stock fuel gauge to work with an LS1
Old Jan 10, 2009 | 03:58 PM
HDon22s's Avatar
x2 you can pick up alot on there.
Old Jan 10, 2009 | 04:56 PM
jj83's Avatar
Thats actually where i came from. I've already talked to those memebers and the big issue seems to be getting the fuel level gauge to work or the EVAP. Apparently no one has figured out how to use both? I came over here hoping that somebody here has.
Old Jan 11, 2009 | 05:27 AM
Jaysz28's Avatar
well if you keep your stock 3rd gen tank, the fuel gauge will work just fine......
Old Jan 11, 2009 | 01:19 PM
jj83's Avatar
I'd like to do that but i live in stupid california so i have to have the EVAP canister. It's gotta be a smog legal swap.
