Picture of connection from Power Booster to back of 5.3
Old 01-11-2009, 10:14 PM
oteixeira's Avatar
PM me, we will make a deal. I need to know if you are including that bracket, or if you will remove it, so I know exactly what to ship your way as well.
Orlando
Old 01-11-2009, 10:29 PM
eviltwin_1987's Avatar
on the trucks with the hydro boost there is just a plug in the back. the fitting is a quick disconnect fitting. there is a thin ring around the edge of the fitting that you push in into the intake and the fitting will then pull out. it is installed by just pushing it back in. the motors that have the nipple for the brake booster is the same way but the fitting has a nipple. same disconnect. the fittings are interchangable. on my lq4 i just ran the booster line to the fitting where the pvc valve goes. I wont run the pvc into the intake anymore. if you need a picture of the fittings or the ring for the disconnect i will take some.
Old 01-11-2009, 10:30 PM
in this picture it is the red ring. just push it in and pull out the fitting at the same time
Old 01-12-2009, 07:09 AM
oteixeira's Avatar
I tried all of those combination's and it did not work, the only thing that pulled it out was brute force, and it broke in the intake. So now I have a piece of that fitting still in there and a hole that can't be plugged in the intake. Do you have a part number for the fitting with the nipple?
Orlando
Old 01-13-2009, 06:59 PM
ls1nova71's Avatar
Orlando, here's the pic of the intake, sorry it's not too good!
Attached Thumbnails Picture of connection from Power Booster to back of 5.3-photo0803.jpg
Old 01-13-2009, 07:40 PM
that looks like the hole for the map sensor
Old 01-13-2009, 07:49 PM
oteixeira's Avatar
That sir is correct!
He was showing me the only damage on the intake, because we are discussing making a trade that will serve us both well.
Orlando
Quick Reply: Picture of connection from Power Booster to back of 5.3
