Picture of connection from Power Booster to back of 5.3
I want to make sure I hook my booster into the right spot. Does anyone have a pic of the back of their motor without the covers on, so I can see where you put your vacuum line from the brake booster?
Orlando
Orlando
ya, and depending on model truck it came out of, you might have to change the "nipple" so you can get the vacuum hose on it.
On mine I had to remove the one that was in it, truck had hydroboost brakes, just bought the right fitting part at gm dealer.
OK, I think I know which one you are talking about, here is a picture of it on mine, but it has a very strange connector, not something I would expect a vacuum line to hook to. Sorry for the quality of the pictures, blame blackberry I guess. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG00033.jpg)
I also have a line off the trans, it tees, one end is in this picture below, just blocked off, and the other end goes no where, anyone have a clue on this?
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG00035.jpg)
Thanks,
Orlando
Thanks,
Orlando
That line isn't blocked off, the white looking piece is the tranny vent line. If there's a T in the line, the other tube probably led to a transfer case or something..
OMG, thank you thank you thank you. I thought I would never figure this thing out. I guess the only thing left is to figure out the darn part number and how to pull that thing out without breaking the plastic manifold. You wouldn't want to sell me yours?
Orlando
Orlando
Darn, it was a plug. I guess it came off a truck that had hydroboost, which would explain the weird side port coming out of the power steering pulley. I am pretty sure I am now completely screwed. I have more of a piece in there then you had. Here are some pics of what I got out:
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG_5121.jpg)
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG_5125.jpg)
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG_5124.jpg)
![](http://i132.photobucket.com/albums/q37/oandcteixeira/IMG_5122.jpg)
So at this point I have a gaping vacuum leak in the intake that I have no idea how to seal or get a new plug into. Worst part is with it in the truck, it is close to the firewall, so not a ton of room to work in there.
Orlando.
Orlando.
Wait Wait....so you are going to send me an intake and a Power Steering pump for just a hydroboost power steering pump?
LOL, I would need another pump in return, and I am pretty sure that is not what you ment, so I guess we cant make that work. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Orlando
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Orlando
You know, I think I may just be an idiot. I have a hydro boost unit out of a mid '80s Chevy truck, and I could have saved us all this headache by plugging it in! LOL, I want to make sure we are talking about the same pump. I have the one with the high pressure line and one normal line out the back, then a 3rd line out the side, that is the one you are looking for right?
Orlando
Orlando
Really,
Now I wonder. I was told (I got it from a salvage yard) that it is an 05 5.3 flex fuel out of a Silverado. It is definitely flex fuel. It has the hydro boost setup on it for sure. Is there an easy way to know engine type by the serial numbers all over this thing?
Orlando
Orlando
