5.3 in a 71 C10
Old Jan 11, 2009 | 09:49 AM
TSterling's Avatar
Default 5.3 in a 71 C10
I'm going to be starting a swap in to a 71 C10 Long box.
Most of the swaps with these that I see use an Auto, but I'm planning on using the 5 speed manual that came with my swap motor. Has any one done this?
Thanks.
Old Jan 11, 2009 | 01:45 PM
ChevyTrukRacer99's Avatar
I have no idea about the 5 speed trans, but i know there are lots of guys that have used the T56 6 speed, so i would assume it is very similar. I'm doing a 6.0 swap in my 70 C-10 right now, good luck.
Old Jan 11, 2009 | 02:11 PM
Shawn MacAnanny's Avatar
How much you selling that 4 wheeler for? Hahaha BTW blue tape works much better forcovering intake ports. I havent heard much abotu the 5 speed swap though.
Old Jan 11, 2009 | 05:42 PM
ls1nova71's Avatar
Are you sure it's a 5.3? I thought you could only get a 5 speed behind a 4.8. Anyway cool project, I'm going to be starting a 71 shortbed project soon....hopefully.
Old Jan 11, 2009 | 06:07 PM
APillow's Avatar
I am planning the same thing only with the 3 speed tranny... As of yet I have no idea how to get the tranny to mate up. Everything else seems straight forward.
Keep us posted.
Also www.67-72chevytrucks.com has lots of swap info.
Old Jan 11, 2009 | 06:50 PM
luckyhenriksen's Avatar
Ya what car had a 5.3 and a 5 speed?
Old Jan 11, 2009 | 07:11 PM
APillow's Avatar
I am a little lost on that as well. The only LSx truck manuals were the 6 speed with granny 1st as far a I know. At least for the HD trucks... Maybe a stripper 4.8 1500 series could come with a 5 speed???
Old Jan 11, 2009 | 07:14 PM
TSterling's Avatar
I was told it was a 5.3, it also has a (/) next to the 5.3 on the block.
Guess I'll find out when the heads come off. The piston tops should be different from what I've read.
I also wanted to make the column shift 3 speed work, but the deal I got for the motor, trans, harness, and ecu I might as well use it all.
Old Jan 11, 2009 | 09:17 PM
Leevon's Avatar
you could get a 1500 with 4.8 or 5.3 / 5 speed. The only ones I've seen in person were base 4x4 regular cab with the 4.8.
Old Jan 12, 2009 | 07:52 AM
JoeyGC5's Avatar
A Tilt manual column is gonna be about as much as an Ididit column, so keep an eye open. Good luck on the swap
Old Jan 12, 2009 | 09:23 AM
Ok well cool swap! I am planning one for my '68
Old Jan 12, 2009 | 11:55 AM
Shon Herron's Avatar
buddy of mine has used a FORD 4spd behind the 5.3 in his rock crawling jeep.
