Lq4 + th400 = ?
Old Jan 19, 2009 | 08:35 PM
luckyhenriksen's Avatar
Default Lq4 + th400 = ?
How do I mate my TH400 to my 2002 LQ4? Do I just need spacers/adapters or a full blown custom converter.
Old Jan 19, 2009 | 08:39 PM
xpndbl3's Avatar
i bought the GM spacer and the longer flexplates bolts through a search on here for the part numbers. This mated up perfectly to my existing TH400 converter.
http://jeepinpete.com/engine_trans_a...ans_adapt1.htm
Old Jan 19, 2009 | 08:44 PM
rao's Avatar
rao
^^ great pictures of what is going on with the spacer.
Old Jan 19, 2009 | 08:48 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
cheaper alternative
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 19, 2009 | 08:59 PM
xpndbl3's Avatar
Cheaper yes, but I feel that the spacer which is bolted into the crankshaft is a stronger design if you're willing to spend $25 more plus you get brand new flexplate bolts in the process.
Old Jan 19, 2009 | 09:09 PM
red83's Avatar
well, i already had arp bolts. so i already had an advantage i guess.
but you can get new grade 10.9 bolts for less than 5.00 at most local hardware stores. i guess its all up to what you want to spend
if you buy a tci flexplate it will come w/ one also (flywheel spacer)
either way will work. its just up to what you want to do
Old Jan 19, 2009 | 10:22 PM
Great thanks guys
Old Jan 19, 2009 | 10:28 PM
Where can I find part numbers on the spacer and bolts in the jeepinpete article?
Old Jan 19, 2009 | 10:32 PM
xpndbl3's Avatar
look at the pictures, they're on the boxes and packaging
Old Jan 19, 2009 | 11:24 PM
Thanks
Old Jan 19, 2009 | 11:26 PM
So I can order that stuff through GM?
Old Jan 19, 2009 | 11:32 PM
djsanchez2's Avatar
I'm sure it will be cheaper through SDparts.
(They are a sponsor)
Old Jan 20, 2009 | 12:13 AM
Ok I was just meaning that they are just GM parts numbers
Old Jan 20, 2009 | 12:18 AM
frojoe's Avatar
My 2005 LQ4 had the flat flexplate with the spacer already installed when I picked it up...
Old Jan 20, 2009 | 12:21 AM
I don't see a part number on the spacer box. I tried the main ones and nothing turned up. But I did find the bolts. They want 5 bucks a piece for them? That seems like a lot but maybe I am just not used to buying Gen III stuff.
Old Jan 20, 2009 | 12:22 AM
I have the dished flexplate. Wanna trade?
Old Jan 20, 2009 | 01:28 AM
Can I use a flex plate from a Gen I SBC? I have a brand new SFI one in my garage that I would love to use.
Old Jan 20, 2009 | 05:38 AM
ForcedInduction's Avatar
no, diffrent bolt pattern. And why in those pics does it show the spacer mounted outside the flex plate. what purpose does that serve?
Old Jan 20, 2009 | 08:41 AM
jbsjunk's Avatar
I was wondering the same thing.
Old Jan 20, 2009 | 08:58 AM
red83's Avatar
the distance is the same on the feet of the converter. it is the pilot hub on the converter that is different.
you can physically bolt it up w/o the spacer or adapter and it will engage the pump and drive fine, but you will have the negative effects of the pilot hub on the converter not being 100% aligned w/ the crank. which in turns will cause really bad vibrations and alot of other really bad things
