HEADERS GURU HELP 72 pick-up/LS1
Old Jan 20, 2009 | 09:53 PM
Got2Be403's Avatar
Default HEADERS GURU HELP 72 pick-up/LS1
Okay i need a fairly specific answer. I have a 1972 chevy truck with a 2001 LS1 mounted with CPP perch mounts. The stock exhaust, which i was hoping to use, wont fit anymore so i need help in finding a set of headers that will work. they need to stay up high and then drop off at the back. I know nothing about headers but here is a picture of my engine set in place.
Attached Thumbnails HEADERS GURU HELP 72 pick-up/LS1-img_1011.jpg   HEADERS GURU HELP 72 pick-up/LS1-img_1006.jpg   HEADERS GURU HELP 72 pick-up/LS1-img_1007.jpg
Old Jan 20, 2009 | 10:27 PM
ryanvv355's Avatar
Take this for whats its worth. I know pacesetter 99-07 silverado headers fit between the frame rails with one notch cut on the passenger side frame. However, that is with the motor pushed all the way against the firewall.
Old Jan 20, 2009 | 10:28 PM
Stu Cool's Avatar
Check out the headers from www.sandersonheaders.com. They have a number of LS1 headers. Not all of them are listed on line, you may need to call and get their catalog. They are great to work with, I bought a set I needed to modify and they helped me with that and then ceramic coated them for me for a reasonable cost.
Pat
Old Jan 21, 2009 | 07:37 AM
JoeyGC5's Avatar
Doug Thorleys are the only sure fire fitting header for our trucks. Other wise frame notching or motor relocating is necessary. I've got Hooker F-bodies on mine and just like the Pacesetter F-bod's frame notching is necessary.
Old Jan 21, 2009 | 08:56 AM
Z284thgen's Avatar
i think a local guy has been using the pacesetter car headers on his swaps
Old Jan 21, 2009 | 09:36 AM
luckyhenriksen's Avatar
I just bought some cheapo F body headers off ebay, hoping to get those to fit. And I am using the CPP stands and stock motor mounts with trans dapt adapter plates
Old Jan 21, 2009 | 08:33 PM
68shortstep's Avatar
im not sure where CPP locates their motor, but ive done a few lsx engines in these style trucks and ive had good luck with the 99-02 camaro/firebird headers (pacesetters, race style)
here are a few pics
Old Feb 1, 2009 | 03:22 PM
Z284thgen's Avatar
go don go
Old Feb 1, 2009 | 05:48 PM
Guys using F Body headers- have you modified the drivers side collector at all? It curves in toward the frame. What have you done to match it up with existing exhaust
Old Feb 1, 2009 | 06:51 PM
JoeyGC5's Avatar
The Hooker long tubes I used had a damaged driver side collector. So I used a 3 to 2.5" coupling to correct the damaged collector and align the exhaust path on both sides.
Old Feb 1, 2009 | 10:11 PM
i cut them at an angle to streighten them out, and weld on v-band clamps to get a perfect leak free seal.....
Old Feb 1, 2009 | 10:13 PM
Looks great
Old Feb 1, 2009 | 10:16 PM
ls1_chevelle's Avatar
My buddy used sanderson shorties. Worked nicely and had lots of clearance.
Old Jun 26, 2009 | 07:11 PM
Got2Be403's Avatar
What kind of engine mounts did he use? what style of truck does he have? could i bug you to get some picture? thanks
Old Jun 26, 2009 | 09:24 PM
LS 60 APACHE's Avatar
nice looking projects trucks and goodlookin work guys!!
intersted in this thread also. those thorleys are nice ,but pricey
