Confused about AC with conversion
I am stuffing an LQ4 into a 67 chevelle that did not have factory AC. I have been trying to mock up the engine placement with the compressor that came with the LQ4. Am I wasting my time trying to get this compressor to fit? I am reading that after market AC kits don't work properly with modern compressors. Would it be best to ditch the LQ4 compressor and either worry about AC later? Or should I actually buy the aftermarket kit and mock that up? Or, can I in fact use the stock LQ4 compressor with aftermarket parts?
Thanks for the help.
Rob
My 68 vette did not have AC so I was going to have to buy all the stuff anyway. Trying to reuse the LQ compressor would only save a few bucks.
I bought a Vintage Air setup and am very happy with their kit.
It was easy to solder the hardlines (aluminum) using a propane torch and pre-fluxed solder rings from docs. Go to their website and see the free videos of how to do it.
Your '67 may have mounting points for a '67 condenser and evaporator, and a formed boss on the firewall for the A/C hoses to go thru.
https://ls1tech.com/forums/conversio...iable-poa.html
https://ls1tech.com/forums/conversio...ble-fixed.html
If you decide on going with the factory compressor then you can pick up an adapter here at nostaligic air for $25 that will allow you to hook up directly to your vintage air.
http://www.nostalgicairparts.com/ac/...dapters-79.php
In addition, there were interference problems with LQ compressor and the frame and A arm that would require more mods. VA also offers a few different mounting locations for their compressor. So what's the advantage to keeping the used LQ compressor vs a new one that's made for the VA kit?
After looking over rodder's pics and suggestion for the kwikperf.com bracket, it looks like I won't worry about AC yet! I guess when the time comes, I just need to make sure I get the Sanden compressor that works with the kiwkperf.com bracket from VA along with the serpentine belt you [Gary] mention.
Gary, any link or pics to your vette build?
Thanks for all the info guys.
Rob
I made my own bracket for AC and alternator to deal with clearance problems and the fact I wanted to use a mechanical fan.
Link to that thread below.
Oh yeah and good point Ghost on the recirculation. But mines a convertable, so if it's masrginal, I'll have the top down.
https://ls1tech.com/forums/conversio...rive-done.html
Rob
Would you please share how you swaped your water pump pulleys?
I know sounds like a dumb question, I know it involves pressing off
and pressing on, but I talked to a local pump & alt rebuilder and they
were not intrested in helping.
I now have a 97 pump with bolt on pulley, spacer between pulley and hub,
but I wonder how long the 97 pump will be avaliable.
Thanks,
Sorry about thread hyjack Rob.
Malcolm
thanks for the pics/thread.
Malcolm
Rob
The F body pulley is so tight between the pulley and pump body that I first had to cut slots to get the a 3 jaw pulley under the edge. Then even with that, I had to cut the pulley near the center shaft with a cutoff wheel to loosen it. Kind of a pain, and I'm guessing there's a jig on a press that the water pump reman. guys use.
To press it on, you will need a hydraulic press. Remove the back water pump cover and support the pulley on only the center shaft. I used a small socket under it. Then just press on the pulley to the appropriate distance on the shaft.
If you support the pulley by the impeller, you'll press the shaft farther through the impeller. Fortunately I discovered this while practicing on the old pump.
BTW, I bought mine off ebay from a guy that rebuilds them (H2OPUMPMAN1@AOL). I also emailed him to sdee if he could supply F body water pumps without pulleys. No reply, but you could try him too. I'll take 2 if we can get a group purchase.
Thanks,
Malcolm
It's J&T Automotive Distributing, Inc.- (417) 468-2439, and no,...it's not my brother-in-law, LOL I'm just a walk in. They are on A hwy. just south of town.
