ac questions for conversion
And if they do swap can i just unbolt it without freon shooting all over the place ?
Just crack a block fitting at the condenser or drier, and let the R134a escape slowly. The A/C system when cold & not running is probably less that 200psi. You can get a mobile A/C guy to come to wherever you are if you want to do the right thing and capture the gas. The mobile guy is handy when you want to re-charge it.
Also buy a compressor o-ring set. Every one I've got from advanced auto was a Factory Air brand which is made in USA.
The good part is it comes in a kit with all the different o-ring thickness combinations.
Just make sure when you bolt it up the block stays parallel with the compressor. If you have the wrong o-rings it will go crooked and leak.
