Ls1 T56 Chevy II clutch setup!
Hey I have a 63 chevy II with an ls1 and t56 setup with the checkered racing front clip. My question is what are you using to setup a master cylinder to engage the clutch with the factory pedals or aftermarket pedals... Any ideas, you guys have any pics...
Thanks Mark Tisdale
Thanks Mark Tisdale
How much did that master cylinder and line run you...
Thanks Mark
Yea I will call tomorrow, I only see stuff for a tremece 5spd but it doesn't matter I am sure, I just need the bracket to mount the master cylinder to the firewall and run the ls1 style braided line... and run a heim joint setup connected to the clutch brake pedal.
Who knows...
Keep some info coming guys!!!
Who knows...
The body on my Rambler American is built like a Chevy II. I mounted the clutch master by copying the way it was mounted in my 99 Camaro parts car. I tried to figure the original mounting angle, drilled a hole in the firewall and bolted it in using the original ubolt setup. After removing the cast section of the pushrod, I put a 1/4-20 thread on the remaining pushrod stub. A rod coupling , a piece of rod, and a heim joint connect to the pedal. Use a pedal stop to limit travel to under 1 inch. The street and performance website has info on making a mount on your clutch pedal. Space gets tight around the steering column and pedals. I even had to slightly offset my brake pedal to clear the clutch master setup. Love the early Novas. Had a bunch of 66 and 67 SS's back in the 70's. Good luck.
Edit: Don't know if this will work for you but its priced right:
http://www.stevesnovasite.com/forums...d.php?t=115529
The braided line was $104 from McLeod: http://store.summitracing.com/partde...0&autoview=sku
I appriciate it!
TTT!!!
I am on similar swap right now on a '66. I plan on using a Wilwood M/C (already had it) and fabricating a bracket that will mount it at an angle to the firewall in the same location as where the original Z-bar pushrod exited the firewall - just above and to the side of the steering column.
I'm currently waiting on my clutch pedal to arrive before I go about making the bracket.
Thanks Mark
I am working on a 63 Chevy II with ls1/T56. I fabricated a master cylinder bracket using the ones they make for early Camaros. It doesn't run yet but it seems that the clutch works fine. I am on a tight budget and this didn't cost that much to do (cost of bracket and stock Camaro clutch master cylinder). You can see pictures at:
http://justinschevyii.blogspot.com/
Hope this maybe sparks an idea. If you have any questions just ask.
Justin
Justin
