What resistor for alt?
Old Mar 8, 2009 | 05:13 PM
JRracing's Avatar
Default What resistor for alt?
What kind of resistor do I need for the alt to see 5 volts? Were is the best place to find them? Radio shack, best buy?
Old Mar 8, 2009 | 05:15 PM
Shawn MacAnanny's Avatar
480ohm most reccomend a 1watt but you wont find one at radio shack. I am running a 1/2 watt and its been perfectly fine. Radio shack carries them in stock for $.99 for 4.
Hey JR whats that fox weigh? also whats you're carb jet size etc. I just put my demon on yesterday from a holley and am curious what people are doing with the pumps and cams on the demons to make the stumble go away.
Old Mar 8, 2009 | 05:19 PM
JRracing's Avatar
Shawn, how many will it take? 1? 4?
Old Mar 8, 2009 | 05:22 PM
You will just need 1 but they only sell them in a 4 pack.
Old Mar 8, 2009 | 05:53 PM
JRracing's Avatar
And that resistor drops it to 5 volts???
Hows that cam working for ya?
Old Mar 8, 2009 | 05:55 PM
Yup it drops it to 5 volts. Some people install a light bulb inline as an alternator warning light and that works too somehow.
Cam is working great man got some nice weather here so i can get some tuning done now
Old Mar 8, 2009 | 06:10 PM
JRracing's Avatar
I think the bulb trick works by robbing voltage before it gets to the alt. That sound shady. Are the resistors a one way type thang?
I'm hoping to be out tuning in a few weeks also.
Old Mar 8, 2009 | 06:12 PM
JRracing's Avatar
I think there was one in the wiring on the car when I got it. I gotta go check the left over wiring. I ran it with 12v going to it. I bet it popped something inside of it.
Old Mar 8, 2009 | 06:14 PM
Nah resistor voltage travels either way. If you have a truck and i think vette alt you have to power the 5v to two pins and with an fbody just the one.
Yeah i want to see some videos of that fox out runing man!
Old Mar 8, 2009 | 06:15 PM
Yeah you if ran 12v directly to the voltage regulator it will charge for a little while but then fry it from what i understand.
JRracing's Avatar
Does your moroso oil pan have a remote filter mount or is it still in the stock location??
Old Mar 8, 2009 | 06:20 PM
JRracing's Avatar
I just had it out in my hood long enough for the cops to get called, lol. It rev's like a two stroke dirt bike. It's going to be pretty nasty. I'm going to up load some pics in a few and a vid my wife took. Check back on my build thread in the drag section.
It's a remote mount and you need a $90 pick up tube plus the remote mount kit and 10an fittings it ended up costing me about $450. If i had to do it over again i would DEFINATELY go with the ATS pan (www.t56kit.com) the thing is BEAUTIFUL and not even $100 more.
6qt pan remote filter with -12an lines with 90* fittings included and gasket plus studs. Also powerder coated clear. Just amazing craftsmanship imo.
Old Mar 8, 2009 | 06:22 PM
JRracing's Avatar
So I need to go to RS and ask for a 480ohm 1/2 watt risistor?
Old Mar 8, 2009 | 06:23 PM
HAha i have a local road about 500ft from my house (i live out in the middle of nowhere) and theres a few houses down and that's where i "tune". People come out of their houses by the 2nd pass and watch and wave. I dont think anyone would call the police here lol. Yeah i'll have to check it out. Are you running an X pipe? I'm running 3" straight pipes into an X and out the sides and it sounds so ******* wicked with the cam.I keep forgetting to get a video. It sounds like a 5.7L motorcycle. At 7000rpm it sounds like its turning 12,000 rpm haha. The X pipe is truly a unique sound.
Old Mar 8, 2009 | 06:24 PM
Yup they will have some. It's in a pull out tray thing where they keep the diodes and stuff. There's a 1/2 watt tray all to itself from what i remember.
Old Mar 8, 2009 | 06:25 PM
JRracing's Avatar
Dam, how much is the ATS pan? My stocker has been cut and it only holds about 4 qts. But my motor is kinda to far forward in the car. so I really need to check the measurements to see what one will fit or have someone custom make me one.
Old Mar 8, 2009 | 06:27 PM
I think its 550 but you still need a remove mount filter. This moroso and ATS pan is about 2 inches shorter in the front but the bottom of my pan is just barely above my K member. Here's the thread about the oil pans i have picture of my moroso and Tyler posted his and some other pans over here.
http://www.pro-touring.com/forum/showthread.php?t=51930
It's always nice to have the extra capacity and the extra baffles for hard launches and cornering. My system holes 8 quarts of 5w30 mobile one and i run a K&N filter.
JRracing's Avatar
LOL, I have 3" pipes with an X and two 12" bullets and turn downs at the axle. It sounds really good.
Old Mar 8, 2009 | 06:30 PM
Haha they sound so awesome with 3" x pipes i think. I have my car tagged in MD as a street rod (no inspection ever unlimited modification and driving) which is pretty hard to get and i dont have to have mufflers, or a roof or door or wheel wells or anything its pretty sweet. I chose to keep most of that stuff though just not the mufflers. It turns heads idling at stop lights and driving. It's just obnoxiously loud outside but not bad inside.
