98 camaro PCM upgrade
Old Apr 3, 2009 | 10:05 PM
pdasterly's Avatar
Default 98 camaro PCM upgrade
What's needed to run a 02 computer besides the harness
Old Apr 3, 2009 | 10:43 PM
LS1-450's Avatar
Temp sensor in driver's side head & upgrade to latest design knock sensors (98's will work, but they suck & the PCM software will be written for the new knock sensors). There may be some more, but I don't recall any.
Old Apr 3, 2009 | 11:20 PM
ryanvv355's Avatar
Correct me if im wrong someone but you can rearrange the pins on a 98 harness to be compatible with the 99+ PCM
Old Apr 4, 2009 | 06:18 AM
poconojoe's Avatar
You are correct
Old Apr 4, 2009 | 12:28 PM
pdasterly's Avatar
I have a 02 harness and computer. Don't I need the speedo also?
Old Apr 4, 2009 | 04:18 PM
LS1-450's Avatar
Do you mean the 02 speedo? Usually, the VSS from the trans goes to the PCM & then out to the speedo. If the speedo used does not accept any on the GM PCM outputs, then either a Dakota unit or an after market speedo are used. What speedo are you using?
Old Apr 4, 2009 | 09:26 PM
pdasterly's Avatar
i have a 98 z28 mostly stock, i have a 02 ss computer and wire harness that i want to use
Old Apr 4, 2009 | 10:09 PM
poolshark021's Avatar
If you want to use the 02 harness you will need to get a 02 cluster and re-wire it as well as a new fuel sending unit. If you re-pin your 98 harness you can keep the old cluster and if you have efilive or access to it you can keep your old fuel sending unit too.
Old Apr 7, 2009 | 11:23 PM
pdasterly's Avatar
the 02 hareness connects to the car via two connectors. the 98 has five, is this goig to be a problem
Old Apr 8, 2009 | 05:43 PM
RE AND CHERYL's Avatar
i have a 02 harness and computer. Don't i need the speedo also?
no...
Old Apr 9, 2009 | 09:35 PM
pdasterly's Avatar
the 02 hareness connects to the car via two connectors. the 98 has five, is this going to be a problem
Old Apr 10, 2009 | 10:25 AM
LS1-450's Avatar
Can you be more specific? What do you mean by car? Do you mean to the dash cluster, transmission, OBDII connector? Do you mean from the PCM to the interior electronics?
