Corvette FPR users, I need some help
Help?!?
Thats my filter/reg install. I don't have any pics of the line to the rail, but I used stock LS1 pieces for a factory OE look.
Re'
Are you removing the Stock F-Body setup, adding a return line to the car and tank ?
Doman does make a repair kit for the GM plastic lines, might look into one of those and fab up what you need. other options are braided lines with AN fitting, compression fitting and maybe some hard tubing.
I am sure somebody will give you a idea for you of where to put it and what to use.! good luck
Re'
