computer/harness connectors needed
Old Apr 9, 2009 | 01:28 PM
s10-den's Avatar
Default computer/harness connectors needed
I dont know where to put this,but does anyone have about 10 pins they want to sell that are not used?I need the ones that connect on the wire and then plugs into the computer.Part # 1208492.I called the local "stealership" and the bastards wanted $4.75 for (((1))) little piece.You can get a bag of 100 for $40, but I'll never use them.No wonder gm is going bankrupt !!!!!!!!!!!
Old Apr 9, 2009 | 02:47 PM
NoClassic's Avatar
http://www.lsxtune.com/shop/index.ph...nfdtlulnoida00
They will have what you need.
Old Apr 9, 2009 | 03:18 PM
s10-den's Avatar
Thanx.....
Old Apr 9, 2009 | 05:07 PM
Pocket's Avatar
http://www.eficonnection.com/eficonnection/100w.aspx
Cheapest Ive found
If you are just after short lengths of wire with the connector then go to a JY and get any mid-late 90's GM ECM harness
3.8 (most), vortec, LT1, LSx truck all use the same terminals
Old Apr 9, 2009 | 06:05 PM
s10-den's Avatar
No I am re-building my harness and just need about 10 or so of these connectors...(new ones)
EDIT:::::Now that just throws a monkey wrench into the game,2 different sizes!?
I need them for a 02 s10 computer......
Old Apr 9, 2009 | 07:21 PM
Pocket's Avatar
Gauge out the wire and buy accordingly
Also, where can you get a bag of 100?
Old Apr 9, 2009 | 07:36 PM
LS1MCSS's Avatar
If they are the same size as an f-body computer, I have a lot of slightly used ones I'll send you, for free. You can solder and heat shrink your wires to them.
Old Apr 9, 2009 | 07:51 PM
s10-den's Avatar
Hey, if they are usable, I would like to have about 10 or so??
