is there any way use the truck acc. in fbody
1 Post
Honestly, it would really be more work than it's worth. I know that things will be a bit different with your car since it's a 4th-gen, but here's a thread that has pictures that show how high the alternator sits in a thirdgen Firebird... And if that's not bad enough, the truck accessories put the PS pump right into the steering box as well.
Finally, I wouldn't even venture a guess as to how much room you have between the engine & the radiator, but that's something you'd need to consider as well.
