LQ4 yr? TH400 spacer needed?
Hey fellas,
I am pretty sure the LQ4 I have is a 2003, which means i should only have to use the regular LS1 flexplate to mount a TH400 to it. Or is it the later ones that need the spacer? Here are some pics of the
casting #'s
Block dating#
Rear crank
casting #'s
Block dating#
Rear crank
I have a 2003 LQ4 in my 2001 SS, use the LS1 flexplate and not the LQ4/4L80E flexplate. Only the 1999-2000 LQ4s used the longer crankshaft, the others (LQ4s) used a spacer in between the (flat) flexplate and crankshaft for the 4L80E. The LQ9 used with 4L60E used the LS1 (curved) flexplate.
That is because your 6.0L was mated to a 4L80E.
You will need the spacer and 6.0L/4L80E flexplate. The flexplate is the same one used from 1999-2007 on 6.0L with a 4L80E. The crankshaft in 1999-2000 6.0L had an extra thick flange to space the 6.0L/4L80E flexplate properly, which was different from the LSx flexplate. In 2001 GM used only one crankshaft and incorporated a spacer for engines used with the 4L80E.
Engine is from an 01 yukon denali if it makes a difference.
I have a 03 5.3L out of an Envoy, what flexplate do I need? Ill be using a Th400 with an Ultra Bell. Just a regular LS1?
Found these,
http://www.exoticperformanceplus.com...html?item=1090
http://www.pirate4x4.com/forum/showthread.php?t=751522
http://advanceadapters.com/product/3...smissions.html
Found these,
Spacer from GM parts direct or local dealer
GM PART # 12563532
CATEGORY: Spacer
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $52.86
OUR PRICE: $31.34
BOLTS
GM PART # 12563533
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $6.86
OUR PRICE: $4.06
Flex plate http://www.crateenginedepot.com/stor...3ykj7OraIvNr7h
Spacer http://www.jegs.com/i/GM-Performance...63532/10002/-1
http://www.crateenginedepot.com/LS1-...-P1343C19.aspx
GM PART # 12563532
CATEGORY: Spacer
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $52.86
OUR PRICE: $31.34
BOLTS
GM PART # 12563533
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $6.86
OUR PRICE: $4.06
I just bolted mine up with all the same parts and I needed to drill new holes. I used 1 existing and had to make 2 new.
