Power steering hose??
Old Apr 20, 2009 | 06:55 AM
Ellis Juan's Avatar
Default Power steering hose??
Im running a 94 Grand am rack and pinion with my fbody PS pump. The fittings on each end of the hose I got from the grand am fit perfectly, but the hose is too short and bent oddly, so I cant make it work. I cut the fittings off, leaving about 4 inches of hard line and flared it. I ran high pressure fuel hose and hose clamps on each end. This is just temporary and Im scared its not gonna hold up. Does anyone make them on the forum? I cant find a shop in town that will make the hose. Any clue on what size these fittings are and who can make them?
Old Apr 20, 2009 | 08:08 AM
jbsjunk's Avatar
Here are a few places in your area that do hydraulic hoses and ends. See what you can get from there. The EFI hose won't last if it even goes a turn on the steering wheel.
http://maps.google.com/maps?hl=en&cl...e-results&cd=1
Old Apr 20, 2009 | 12:56 PM
Rodder's Avatar
That won't work for the pressure line, but it'd be ok for the return line. Power steering can be up to 1500psi on the pressure side.
Old Apr 20, 2009 | 04:34 PM
Ellis Juan's Avatar
Wow..Didnt think it got that high. It lasted just fine until I went lock to lock and heard the hose pop. I may go take a walk through the junk yard and look for some GM vehicles..maybe there is a PS line that will be bent pretty close to what I need.
Old Apr 20, 2009 | 07:35 PM
topher455's Avatar
Any hydraulic shop can make it.
Old Apr 20, 2009 | 09:44 PM
S10xGN's Avatar
Cut your flares off and use a pair of compression unions with a piece of steel brake line (yes, it comes in sizes up to 3/8").
Russ
Old Apr 20, 2009 | 10:59 PM
Ellis Juan's Avatar
I did the compression thing to start with and they seeped. Probably my fault for over tightening the compression fitting. I then went to the flares and hose clamps. If I cant find someone to make the ydraulic hose Ill go back to the compression fitting. Freekin braze them on if I have to. Im ready to get on the damn road.
Old Apr 20, 2009 | 11:41 PM
G-Body's Avatar
sawzall wielding director
Have you checked NAPA? they can usually make hydraulic lines, but I have heard that if you tell them its for steering they won`t touch it. I think it is kinda a don`t ask don`t tell thing.
Old Apr 21, 2009 | 05:40 PM
Ellis Juan's Avatar
Went to napa today. I ask them the last TWO times ive been in there, but the guy said they couldnt make the hose with what I had. This time however the owner was there and was like YEAH, come on back. They made me a hydraulic hose the length I needed with compression fittings on each end. Not the weak brass compression fittings either, these are steel. You can really get down on them and they will lock in. Thanks for the replies. Problem solved!
Old Apr 24, 2018 | 08:37 PM
dawgs74's Avatar
Russ
will brass unions work or does it matter? Opps old thread again.....
Old Apr 24, 2018 | 09:11 PM
B52bombardier1's Avatar
Or just go to NAPA and have a custom hose made. Cost me $50.00 plus tax for a perfect length hose, no twists or kinks.
Rick
