6.0L with m21
What flywheel and clutch can I use to get this done? Do I use a flywheel for that year truck? or?
McLeod makes a new flywheel for this conversion specifically. There's may different opinions on this subject..You'll be able to use any off the shelf 10 or 11 inch pressure plate. And any 10 spline disk.
Some guys I know are just running the ls7 clutch set-up with a hydraulic throw-out bearing.
http://www.keislerauto.com/index.php...using-kit.html
There are a lot a variables to this swap. For one is the difference between GEN I and GEN III/IV motors crankflange locations relative to the bellhousing flange on the back of the motor. GEN III/IV motors are recessed by .400" this is the reason McLeod made the "adaptor" flywheel. Once again, it can be done with the a regular flywheel but the clutch disc rides a little close to the end of the splines for my liking.
You could use the McLeod flywheel, get a BB bellhousing if you dont already have one, and an extended pilot bearing which McLeod makes also. This way you can use the clutch you already have, a normal TO bearing and use the mechanical linkage if you want. You also have to get Scoggin Dickey's ball adaptor bracket to use the mechanical linkage...
Let me know if someone makes an adapter flywheel for it.
https://ls1tech.com/forums/conversio...ent-4l60e.html
In addition I suspect the splines on the trans input shaft will hit the pilot bearing before the trans is seated to the block.
