LQ4 or LQ9 how do I know?
If you do not have access to the Denali, can you at least get the VIN? You can probably call GM and give them the VIN and find out.
6.0 LQ 4'S came in 01+ Denali's, 00+ Truck variant's, and Vans, all with 8th digit vin: "U"
cylinder. If you cant see the top of the piston turn the crank a little then use a coat hanger with the end folded over (to make it dull) and feel across the top of the piston if it is flat all the way across it is an LQ9 if you feel it raise up near the edge of the piston its an LQ4. HTH Chris
Final thought: I have checked several motors this way. I have purchased two "lq9 engines" and paid a premium for them. I have found both of them to be lq4's with this method and sent them back. The guys at the yard are always like "woops" but theyre thinking FUCKK howd he know? If it was sold to you as an lq9 dont take any crap you've got a reciept that says you bought an lq9 so you deserve one. Dont let anyone tell you there isnt much difference. Theyre wrong. I pulled a couple apart and the rods are better, the wrist pins are full float, and the pistons are lighter as well as made of better material.
I am not saying the question is dumb or anything like that, but these 6.0L truck engines are very popular among us (the budget builder), so IMO someone should make a sticky about how to difference them.
Sorry if I am missing that sticky.
And to help with the question, I took off the spark plugs, then with a slim long flat head screw driver I looked for the piston that were higher in the cylinder, then started to feel the piston surface or piston head or whatever (I´m not a tech). In my case I had the chance to try that with both an LQ4 and LQ9, and the difference is very obvious. So if you do that and do not feel the dish, you got a `9
Way to go.
Get me the VIN Derivative and I will give you the info
4.3L, VIN X or W(03+) (8th digit)
6.0L, VIN U (8th digit), (LQ4) Trucks, Vans and Denali
6.0L, VIN N (8th digit) (LQ9) Escalades & SS Silverado
4.8L, VIN V (8th digit)
5.3L, VIN T (8th digit, opt LM7)
5.3L, VIN Z (8th digit, opt L59)
5.3L, VIN B (8th digit, opt L33 05+ HO aluminum and iron block with 243/799 heads)
FYI: 07+ Trucks
classic body style, 6.0L, VIN U (8th digit, opt LQ4), natural gas and gasoline
classic body style, 6.0L, VIN N (8th digit, opt LQ9)
classic body style, 4.8L (VIN V, 8th digit, opt LR4)
classic body style, 5.3L, VIN T (8th digit, opt LM7)
classic body style, 5.3L, VIN Z (8th digit, opt L59)
classic body style, 5.3L, VIN B (8th digit, opt L33)
classic body style, 4.3L (VIN X, 8th digit, opt LU3)
new body style, 5.3L, (VIN 0, 8th digit, opt LMG)
new body style, 5.3L, (VIN J, 8th digit, opt LY5)
new body style, 5.3L, (VIN 3, 8th digit, opt LC9)
new body style, 5.3L, (VIN M, 8th digit, opt LH6)
new body style, 6.0L, (VIN Y, 8th digit, opt L76)
new body style, 4.3L, (VIN X, 8th digit, opt LU3)
new body style, 4.8L, (VIN C, 8th digit, opt LY2)
FYI:5.3L: 2003-4 GMC Truck Envoy XL, 2003-4 Isuzu Ascender , 2003-4 Chevy TrailBlazer EXT (all with VIN "P", 8th digit) & 05-06 (all with VIN "M", 8th digit)
