Lsx 302?
Old Apr 30, 2009 | 02:36 PM
Importmd's Avatar
Default Lsx 302?
Ive been planning on swapping in a LQ9 in my 95 Z/28 this winter, but after reading about GM's concept 302 camaro it got me thinking. I cant find a hole lot about building one. my question is, is it as easy as taking a 5.3 and using a 4.8 crank? any input would be great.
http://www.zlx.com/camaro/302c.htm
Old Apr 30, 2009 | 03:17 PM
NemeSS's Avatar
just bore 4.8 .060= 5.0
throw on some 243 or 799, ls6 intake, gt11 cam. al supporting bolt ons, etc.
4.8 is a great engine, rpms very quick, sounds good, runs hard even in pu trucks
Old Apr 30, 2009 | 03:23 PM
Pop N Wood's Avatar
Why give up all that power by reducing displacement?
funny how they call it "high reving" then quote a HP peak at 6000 RPM. My 6.0 does better than that.
If they want to stay true to the spirt of the early Camaros, how about shaving a few thousand pounds off the cars instead?
Old Apr 30, 2009 | 05:06 PM
Importmd's Avatar
so what would you get if you through in a 4.8 crank in a 5.3? the only reason i ask is because i already have a free 5.3.
Old Apr 30, 2009 | 05:20 PM
Datsun350Z's Avatar
Why not keep the 5.3 as it is?
Old Apr 30, 2009 | 05:26 PM
Importmd's Avatar
i thought it would be cool to build a high reving 302 like the old school z28. if not, i will stick with my 6.0 plan
Old Apr 30, 2009 | 05:27 PM
Bo185's Avatar
You get another 4.8!!!! The only difference between the two is the crank! The bore is the same!!!
Why not swap the 4.8l crank in the 6.0l and have a fast rev'ing 5.3L!
Old Apr 30, 2009 | 05:35 PM
NemeSS's Avatar
4.8/5.3 use same bore same block
diff cranks and rods.
5.3=3.622 stroke
4.8=3.268 stroke
Old Apr 30, 2009 | 05:36 PM
NemeSS's Avatar
will have to use 4.8 rods as well with balanced 4.8 crank to new 4.00+bore pistons.
Old Apr 30, 2009 | 06:03 PM
Importmd's Avatar
thanks guys, one more thing. the 4.8 has 6.278" rod length, i need 5.7" rods? to achieve the 302. are all gen motors rods the same? or are the 3rd gen only? thanks again
