Autokraft Oil Pan Install
I just got an autokraft oil pan and I did not receive any instructions. My question is do I use the stock windage tray or not? Will the pick up tube be fine with out the windage tray? Also do I have to do anything to make the dip stick tube work? Thanks in advance!
I just installed an Autokraft pan on my LS1 with the Edelbrock conversion and you need to check to make sure that all of the pan bolts on the drivers side are drilled and tapped. The oil filter adapter came into conflict with the header and I had to modify the block off plate so it would clear and also not get too hot.
