help with wiring PLEASE HELP!!
Old May 25, 2009 | 04:31 PM
getsum27's Avatar
Default help with wiring PLEASE HELP!!
ok so im putting an ls1 into a foxbody mustang and i just got all of the stuff a couple of days ago and i was going to start with deleting the un needed wiring for the body harness but i have a problem
every thing came out of a 99 and i have looked on here for hours and the diagrams for 98 and for 99 up do not match mine
i started with the dlc connector and pin 2 on the dlc goes to connector 230 and it is a purple wire that goes to pin G on C 230 which all of the diagrams say it should be a drk green wire that goes to pin k so i stopped when i got to that point and figured i should find out befor i go any further
Im not sure that it is connector 230 it says that no where but that is what it is supposed to go to but all of the wires seem to be different on this plug
Please help
Old May 25, 2009 | 06:16 PM
the_merv's Avatar
That wire you are talking about is the Serial Data Wire.. it can be purple or green. For instance on my Car it's purple but on the Engine Harness it's green.
C-230 is the blue connector.
Old May 25, 2009 | 06:19 PM
getsum27's Avatar
ok yeah i got it thanks can you tell me how to identify all the connectors that i need to eliminate wires from
for example
c100
c101
c102
c105
Old May 25, 2009 | 06:26 PM
the_merv's Avatar
That depends on what you have and dont have man.. you have a pin diagram of each?
Which one is C-102..never heard of that one..
Old May 26, 2009 | 11:08 AM
getsum27's Avatar
is the fuse box from the camaro completely deleted when wiring into a fox body from what it looks like the only thing i will need from the body harness is the wiring for the gauge cluster the dlc, and c220, c230 is this correct im not a wiring guru by any means but i want to do this myself and all help is appreciated
Old May 26, 2009 | 11:35 AM
the_merv's Avatar
Me personally I would use the 1995-1995 F-body fuse box, they are simple.
