How hard is it to swap an ls2 intp my 98ss?
#41
I have my opinion and so does everyone else.
If you like to criticize people you much better off not posting at all. Like the old saying goes "You don't have nothin nice to say don't say it at all".
I have nothing against anyone here. And I am willing to learn, sometimes you gotta make mistakes in order to learn. Obviously I learned something new no need to bash over it. After all it just shows your an e-thug.
PS: juiced Z28's comments ain't the best way of stating things and sure, they aren't the most constructive in helping you find your mistakes and learn from them (if, you indeed are learning anything from this), but damned if what he said doesn't cut to the chase.
#44
LS7 heads on an LQ4/LQ9 are a no go due to cylinder diameter.
OneBadLS, no matter how strong you build an engine... High boost w/ high compression is just not going to work on a gasoline engine. I believe you'd start running into major detonation issues if you do. Show me an example of a high compression (10.5:1+), high boost (15psi+) engine that runs well, import or domestic, iron or aluminum. Going with lower compression facilitates higher boost and more power. It really doesn't have anything to do with tuning. A good tune is a good tune, most of the guys that would go out of their way to FI an engine are probably going to spend some time an money tuning it. This is not about what is reliable, its about what works or not. In this context, those are different things.
Look man no offense, but if this many people are disagreeing with you and nobody is backing you up... it may be time to go read some more.
Just realized this thread had nothing to do with FI... interesting. That being said if you are going FI and are keeping the bottom end the way it is for a mild setup, a later LQ4 would be the way to go. If not the LQ9 is a nice higher compression version. If your going to build the bottom end, either will do (with the LQ4 being more affordable and easier to find)... but that probably goes without saying to the OP.
I could elaborate but it's time to go to work. On another note, my '81 240 2-door is going under the knife next month beginning an LQ9/T56 swap.
