45 degree flare to -6 AN adapter?
I have never used any AN fittings before, but I've read up here and went to the auto parts store to at least look at them. My setup is going to be almost exactly like the 67rsss schematic and like Bczee's. I believe I have it all figured out as to what I need now, except for an adapter at the fuel tank.
On my Spectra EFI tank from rockauto.com, I have a male 45 degree flare with 3/8-24 threads.
It comes with the female fitting to use hose and clamps with that I don't want to use....
I am hoping to find an adapter that goes from female 45 degree flare, 3/8-24 to male -6 AN. Does anyone know if such an adapter exists?
I have ordered all fittings, hose and tubing I need to plumb for fuel but haven't figured out how to adapt to tank without cutting 45 degree flare off. If there is no such adapter, how did others do it?
Thanks!
Rob
http://www.pegasusautoracing.com/adv...ryID=PLUMADAPT
If I was going to do it again.. I'd take the sender off.. and just get some 3/8" and 5/16" AN -6 Threaded ends and just braze them on... No compression fitting, no Quick Disconnect fittings at all.
That is what I did on my Fuel Rail... Would have done it on the sender if I had thought about it before I spent all of the cash for adapters and QD's.
Andy1
Rob
Rob.. I'm sure someone you know or shop will do it cheap..a 6 pack or something !
Russell makes an adapter pn #640610
http://www.summitracing.com/parts/RUS-640610/
http://russellperformance.com/mc/adapt_fit/fuel.shtml
Thanks for trying.
I will measure the outlet line a if it has an 3/8" OD, I will try to heat off the origial fitting and use a compression fitting.
Unless anyone can come up with a better way.
Thanks for trying.
All this and sounds like I won't the spectra tank when all said and done.
Thanks for the reply
http://www.aircraftspruce.com/catalo...ringtools3.php
This will make female 37degree flares in steel or aluminum tube easily.
Buy some tube nuts and the matching tube sleeves (they go on the tube before you flare it), and then buy a male -06 AN hose end of choice. I prefer to use the Russell braided teflon stuff because you can assemble them at home with hand tools.
I use mine to make custom steel brake lines, fuel lines, ect. Well worth the investment and produces leak proof connections.
