View Poll Results: Which one and why?
TH700R4
11.11%
4L60E
66.67%
Bacon!!
22.22%
Voters: 9. You may not vote on this poll
Transmission options
Old Jul 3, 2009 | 05:11 PM
FrankZ's Avatar
Default Transmission options
I posted this same question on a local 4x4 forum but thought I get a few more opinions here as well.
Basically I'm looking for opinions on which tranny to use in my Cherokee behind my 5.3L, 4L60E or a late model 700R4?
What say the masses? Be honest and tell me your version of the pro's and cons of either or both.
Old Jul 3, 2009 | 05:36 PM
bustac's Avatar
Default transmission
Where's the 4L80E option?
Old Jul 3, 2009 | 05:38 PM
FrankZ's Avatar
Ummm, there isn't one.
I'm concerned about that tranny eating too much power.
Old Jul 3, 2009 | 05:49 PM
Bo185's Avatar
They are the same transmission basically, save for the 4l60 is computer controlled. You will need a cable TB if you pick the 700R if you already have DBW do the 4l60.
Old Jul 3, 2009 | 06:10 PM
FrankZ's Avatar
Not quite the same.
It looks like it's a full 2" longer than the 700r4.
Old Jul 3, 2009 | 07:40 PM
Bo185's Avatar
Originally Posted by FrankZ
Not quite the same.
The 4l80 is different!!!!! I was talking about the 4l60!!!!
The 4l60 and 700r are the same size, gear ratio, and output spline. The 4l60 is what GM changed the name of the 7004 to when they renamed their transmissions. 4=fwd gears L=longitude mounting 60= veichal design weight 6000# E=electronic!
The early ones had one piece bellhousing just like the 7004 then in mid 97 they went to the removable bellhousings.
Old Jul 3, 2009 | 07:46 PM
FrankZ's Avatar
Yep, knew tha, but good info none the less.
My comment about the size was related to the 60 vs 80. Let's try this. From
http://www.pswired.com/95silverado/p...L80rebuild.htm
4l80E on top, 4l60E on the bottom.
I'm limited on space and the 80 propbaly won't work under my rig. Looks like a fine tranny but it would require a redesign of my long arm suspension/crossmember to make it fit.
Old Jul 3, 2009 | 07:50 PM
FrankZ's Avatar
Two votes for Bacon and no supporting commentary!?!?
Well I guess bacon needs no support, it is after all BACON!!!!
Old Jul 3, 2009 | 08:14 PM
Bo185's Avatar
You don't want the 4l80 with the 5.3L it will eat up to much power and plus the 4l60 has a better first gear anyway and you really need it off road!
Old Jul 9, 2009 | 03:30 PM
FrankZ's Avatar
So stopped off at a local salvage yard today to price out a motor or two and one of the counter guys told me that the 2000 4l60E I have won't work behind anything but a 99-2000 5.3L
Anyone able to confirm that?
Old Jul 9, 2009 | 04:07 PM
mramay's Avatar
Don't know what you're planning to spend but I had a custom 4L60E made to handle a slightly modified LS6 (480HP) for $1500, no trade in. That was maybe two years ago.
Where are you worried about the power? If it's highway, the 4L has a locking torque converter. If it is in first gear while rock climbing/off-roading, I'd expect the newer tranny (4L) to be better but I'm not sure.
The other solution is a bolt-on supercharger and then you don't especially care how much the tranny robs from the drive train!!
Old Jul 9, 2009 | 04:14 PM
NemeSS's Avatar
th350
