LS muscle car oil pan kit, anyone use it?
http://www.superchevyperformance.com...p/19212593.htm
I need a rear sump to swap out w/ my GTO pan... this looks like a great buy.
Does anyone have any experience w/ this set up... couldn't tell what pan this is, or if it's unique to this part number.
edit: looked again... looks to be a H3 pan.
What you looking to put it in though??? Might help.
Going in a toyota truck... told an F-body pan will work... just saw this while I was looking at the f-body pan and thought "hmm"
Ya, I had planned to call to see if they actually have them in stock before I ordered it as I've seen that they are on "national back order". So I doubt they actually have one on hand. There *is* one on ebay right now for a bit more than that.
Great Buy! if they were in stock
BRP hotrods sells the kits too wih there own diff name but same thing.. just more expensive.. ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
http://brphotrods.com/Oil%20pan.html
wonder where there getting those from^^^
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I can buy it through my local dealer for less then that.
I bought one as pieces when they were on national back order the first time, plus i didn't need the baffle since I was replacing a truck pan and the baffle is the same
i bought this kit thinking it would work on my 62 impala. WRONG!!!!! Had to order F-body oil pan and it worked fine. But i still need to raise the engine mounts atleast 1/4" to 1/2" due to the lack of clearance with the pan and crossmember.
For realsies. That LH8 pan aint all its cracked up to be cuz of the DEEP sump its got. I used the Moroso #20140 pan, and it clears the crossmember on top and in behind. Its a little trickier to get the motor in place, but it goes. I am still using the dipstick and windage tray from my LH8 kit cuz I broke my truck dipstick tube getting it out, and I didnt feel like changing the tray for no reason.
