LS6 electronics
Old Nov 16, 2003 | 11:31 AM
David(TX)'s Avatar
Talking LS6 electronics
I have a 62 Vette with an LS1 and a T56. I used a 98 PCM and I modified the factory harness. It works great, but is there better?
I am starting a project on a 63 Split Window Vette and plan to use an LS6 with a T56. I have an 02 T/A PCM but no wiring harness.
Now the question, What is the best year PCM and harness to use for a project like this and why? I do not care if I need to get a different year PCM.
Thanks for any input.
Old Nov 16, 2003 | 11:13 PM
John B's Avatar
Moderator
I would make sure and match the wiring harness year to the PCM since there were a few subtle changes between '98 & '02.
Old Nov 17, 2003 | 07:40 AM
David(TX)'s Avatar
Default Modified 180T
Thanks for the imput. But I have a question related to your porfile. What is the modified 180T. Modified how?
Old Nov 17, 2003 | 02:49 PM
Coolvet's Avatar
I got Howell Engine Developments to set up my PCM for my LS6 and T56. They sold me a new harness as well. Does your car use a Newman chassis?
Old Nov 17, 2003 | 05:08 PM
David(TX)'s Avatar
Default Newman Chassis
Yes. Both the 62 which is done and the 63 that is a work in progress use Newman Chassis.
Old Nov 17, 2003 | 06:14 PM
LS-1st-Gen's Avatar
Coolvet, what was your experience with howells harness like??? I had several problems with mine, specificly the PCM connectors being switched, improper VSS connector, and the O2 plugs being switched. They were never able to really help me with my problems, (speartech helped out on that) but when i finally did figure out what was wrong they were able to repair it witout trouble.
Overall I dont think I would purchase another harness from them, or TPIS since that is the distributer I actually got it from.
Old Nov 17, 2003 | 07:44 PM
David(TX)'s Avatar
Default 67 Camero
I have thought of a 69 Camero convertable with LS1 as a project. How do you like the 67? Is the suspension all stock? Do you have any pictures?
Old Nov 17, 2003 | 09:01 PM
John B's Avatar
Moderator
I modified it to make it a 180° thermostat. Check this out http://teamzr1.com/modstat.html
Old Nov 18, 2003 | 07:46 AM
David(TX)'s Avatar
Default Adjustable Temp
Thanks for the tip. I will use that in both my cars.
Old Dec 24, 2003 | 07:20 AM
Shaky2ls1's Avatar
Default http://www.choiceautowiring.com/lsseries.htm
This guy has Canadian funds and awesome work cheapest deal around for
sure, I looked everywhere and also have a friend using one from him as well
as mine. Top notch stuff and very easy to deal with .
(very knowledgeable)
(just a happy customer trying to save you money)
my motor was 98 and he used 2001 computer and harness he custom made
and all fine. $1495 Can or 1,135 bucks Us including programmimg,
supplying computer and harness.
Old Dec 24, 2003 | 07:24 AM
Shaky2ls1's Avatar
I also think the newer computers are better for upgrading with higher maf tables and higher resolution. So if upgrading to ls6 I would think this would be important.
Old Dec 24, 2003 | 04:16 PM
Coolvet's Avatar
Hi LS1-1st-Gen, I haven't completely fitted my harness as yet so I will checkout the connectors that you mentioned. Thanks.
