Mustang lsx begining
Old Aug 19, 2009 | 08:21 PM
sum guy's Avatar
Originally Posted by key4
I am also wanting to know about the kmember as well. I am getting ready to buy one and need to know what all I need to make it work. I was also going to order the kooks headers too. I am a noobie at this and wanting the easiest way out.
thanks
Josh
There is a swap k-member, mounts, a-arms and manual rack in the classifieds for $600 obo seems like a good guy to deal with. Oh when I talked to AJE today he said you need his A-arms to clear either swap headers? Others should chime in here. Djquck88 looks like he used stock ones with the kook headers.
Old Aug 19, 2009 | 08:43 PM
key4's Avatar
Man sounds like you got a good deal on the kmember. How are you going to do you the steering? I am trying to get out as cheap as I can. If I can buy the aje kmember for 350 and use my stock a-arms that would be awesome. Keep this thread going cause I am learning alot. Also has anyone used the dynatech headers and how do they fit?
thanks
Josh
Old Aug 19, 2009 | 09:47 PM
sum guy's Avatar
Hopefully if every thing works out Trading my manual rack with djquick88 ps stuff. You are probly refering to the plumbing right? On my 71 swap I found some fittings from summit that converted the stock6.0 ps pump high side fitting to 6an(can find the #if needed) and a different adaptor for the 71 gear box and got a 3foot line made for $25 (the one I made kept blowing off)The low side was just bulk 3/8 ps line. I here maximum motorsports has these for a ford rack. Hope that helps.
Old Aug 19, 2009 | 09:59 PM
key4's Avatar
sorry, my questions is will the stock rack on the stangs work? I see alot of people using the flamming river rack but if I can use mine and save some money I will. Mine is a 4cylinder car tho dont know if its a difference between the 4cyl and the 8cyl cars.
thanks
Josh
Old Sep 21, 2009 | 09:18 PM
sum guy's Avatar
Just got my engine. Ended up getting a 2004 gto 6 speed pull out with 48k. Headers and hp tuners next on the shopping list.
Old Sep 22, 2009 | 06:45 AM
can'tfindausername's Avatar
thanks
Josh
Yes you can use your stock rack. The 4 cyl have a different ratio than the 5.0 cars, but it's not a huge difference. I'm running my 5.0 ps rack on my LQ4 with the AJE k member
Old Sep 23, 2009 | 09:30 AM
key4's Avatar
good deal. So far I've got got a motor out of a 06 3/4 ton truck with 41k miles, powerglide tranny but needs rebuilt, mines a 4 cylinder so I picked up a 8.8. Got the kmember in the car and decided to go with the flamming river rack and pinion. Just installed a coil over conversion kit to get it back rolling and I also picked up a carb intake.
Hopefully I will beable to score some stuff at the LSX shootout. I hope I can pick up a set of headers, msd 6010, oil pan. I also need to find a starter and altenator.
Keep us posted with the build and let me know how everything fits.
Old Sep 23, 2009 | 09:56 AM
darren s's Avatar
Cool build, I'm doing something similar. Keep the info coming
Old Sep 23, 2009 | 03:08 PM
djquik88's Avatar
Yeah, You can use the stock A arms.
Sum Guy - I have that piece of the steering shaft for you. give me a call when you get a chance.
Mike
Old May 26, 2010 | 02:23 PM
djquik88's Avatar
Updates?
