Mustang lsx begining
Hooks headers $699
AJE and mounts $418
Pcm programing and wiring $750
Fuel pump, corvette filter, lines and fittings $350
Drive shaft work $300
clutch $200
exhaust $400 roller has none
fluids, filters, gaskets, misc $300
trans mount $160
Radiator fan assembly and stock inst. cluster. $250
Turbo coupe pedals?
So thats $3827 plus tax and shipping. (guesing on alot of these correct me if needed)
Motor and trans. up to $4500
So $8327 plus car $2500 = $10827
I think a ls1 six speed would be worth that to me. Anbody seen what such a car would sell for?
So looking for any of the above mentioned parts, Advice, comments. Thanks.
David
Hooks headers $699 - Go with 5.0 headers on ls1 flange. Save assload of $
AJE and mounts $418 - This is fine, I'm doing motor plate to save this $418!
Pcm programing and wiring $750 - Do your own I have $150 in my harness!
Fuel pump, corvette filter, lines and fittings $350 - Shouldn't cost nearly that much for fueling, walbro 255 pump is only $70 so maybe $200 total!
Drive shaft work $300 - Not for sure about this one but prob close.
clutch $200 - I'm auto
trans mount $160 - Fab up your own for alot cheaper.
Radiator fan assembly and stock inst. cluster. $250 - Radiator setup, $130 cluster is maybe $50.
Turbo coupe pedals?
Motor and trans. up to $4500 - WOW, Go with a 5.3 I got mine for $100 complete long block.
David
. Also,If I were you I would go the 6.0/T56 route. Just be sure to get an '01+ 6.0 due to the crankshaft length. A realistic price for a 6.0 is about $1000 .If you need anything, let me know.
Mike
Good news to me. Do you have to get either of these coated?
Mike
Thought about a 6.0 thats what I put in my 71 nice power. Thought with having to get a car intake, pan ect. plus weight savings might be worth it to do ls1.
I read in your thread you regret doing the six speed and went auto. Why is that?
Did Cline do your drive shat work? What about header coating and exhaust?
The stock A arms will work fine. That's what is on my car. If you want a 98 F-body harness for $150 let me know. I'll put you in touch with someone who has one.
thanks
Josh
Hooks headers $699
AJE and mounts $418
clutch $200
trans mount $160
Turbo coupe pedals?
David
Sounds good, I'll PM you my phone number.
I had my drive shaft made at Carolina Driveline off of Howard street, near Hearon circle. Actually they have made a few for me over the years.
I had the headers coated at Millennium Performance Coating in Simpsonville. He does good work.I plan on getting him to coat all of my turbo tubing when I get done.
