late model transmission behind a sbc
I think your on the right path as far as just needing the correct flexplate or Converter.
You will also have to use a Trans controller for the 4L80e. I think there are a few companys that markets them, have you looked into those yet ?
If you can't, then the converter will have to be modified.Trending Topics
Rossler also has a manual trans harness for $250ish that doesn't require a computer to control the 4l60 and 4l80
