Pics of my now completed 67 Firebird with LS1
Old 08-29-2009, 09:44 PM
Steve88's Avatar
Default Pics of my now completed 67 Firebird with LS1
Here are a few pics of my 67 Firebird with a LS1 conversion. I used a new GM crate motor with a Fast EFI set up and a turbo 400 with a gearvendor overdrive. I used the Carshop 1" set back mounts, hooker headers, and a AutoKraft sheetmetal pan.
Old 08-29-2009, 11:04 PM
71 chevy's Avatar
wow, thats a really clean setup. and a really clean car. NICE
couple of questions
how are you adjusting the tension on the belt? the heim rod?
are you still using any tensioners?
which spark plug wires are you running?
Old 08-29-2009, 11:05 PM
MISLLEAD NOTCH's Avatar
Realy clean car bro! Its awsome congrats on ur succes!
Old 08-30-2009, 12:13 AM
LS1MCSS's Avatar
That's a nice ride. How do like the Fast injection?
Old 08-30-2009, 09:10 AM
Stu Cool's Avatar
Very nice! I bet you get a lot of "What engine is that???" When you raise the hood.
Pat
Old 08-30-2009, 09:16 PM
Steve88's Avatar
couple of questions
Thanks for the compliments guys!
I am not running any tensioners other than the heim rod. I could not get the alternator in the stock location due to the set back mounts so I made a bracket and moved it up top to the get the wrap on the water pump. I have seen a few guys with the tensioner mounted low in the alternator location and I may give that a try later but the current system seems to work OK. The plug wires are from Blanco99SS here on the board. He is a vendor and makes plug wires to whatever length you give him.
Stu Cool,
You are exactly right--most people are confused when I pop the hood! The guys that are into LS1's know what it is but most others don't.
Old 09-01-2009, 02:41 PM
jetback73nova's Avatar
is the trany mount in the stock location? I have heard the these 1" setback mounts put the engine in the stock location allowing for the use of stock trany, crossmember and drive shaft (with the proper stuff to link old trany with LS).
Old 09-01-2009, 04:32 PM
stroker_SS's Avatar
Beautiful car, and i love that fast inj. set up also. Got any vids?
Old 09-01-2009, 04:34 PM
35thLE02's Avatar
Wow that looks really nice.
Old 09-02-2009, 09:54 PM
Steve88's Avatar
Thanks guys!
The 1" setback mounts did put the rear of the motor very close to the stock position. I loosened the bolts in the crossmember and pulled the transmission right up the LS1 which was about 1/8"- 3/16" further forward than the small block tha it replaced then the tightened the bolts up.
This car may be for sale soon so if you know anyone looking let me know!
Old 09-02-2009, 11:47 PM
Redrumls's Avatar
How much was that fast fuelie set up? I've been seeing them in mags and looks like it would work pretty good. How does engine run with that setup?
Old 09-06-2009, 12:10 AM
Steve88's Avatar
The FAST EFI system was about $1700. It works well and has amazing throttle response.
Old 10-12-2009, 10:48 PM
Steve88's Avatar
This car is now for sale. Just to claify--I mentioned a Gearvendor Overdrive in the post above but that has not made it into the car yet and is not included, but can be! Thanks
https://ls1tech.com/forums/vehicles-...-fast-efi.html
Old 10-15-2009, 07:54 AM
JonRagTop's Avatar
Nicely done.
Old 10-15-2009, 09:48 AM
SIC LSX's Avatar
damn nice! Ya should of put a good cam in it
Old 10-16-2009, 12:45 AM
turbo.trex's Avatar
I love that car .....
What all comes with it... So is it a plug in play .. What kind of power can it handle thanks...
Old 10-16-2009, 07:16 AM
71 chevy's Avatar
can I ask which oil pan gaskets you used?
Old 10-23-2009, 11:24 PM
Steve88's Avatar
Thanks guys!
It pretty much came with everything required except for the fuel pump and regulator. You can get the system with a pump and regulator also for a little more but I did not need them.
Old 10-23-2009, 11:27 PM
Steve88's Avatar
I used the stock one that came on the motor. The crate motor had a GTO pan on it from the factory so I swapped the pan and used the same gasket.
Quick Reply: Pics of my now completed 67 Firebird with LS1
