A-body-LS Friendly Center Link
+3 on this one, somebody fab something god damn it! I'd do it, but you dont want my welds on your car
Regards, John McGraw
To be moving the location of the center links ends, Pitman/Idler arms would be messing with the front suspension geometry. Bump and Roll steer would suffer the most. You can get a drop center link, but the ends will most likely be in the same OEM location with only the center section being lowered. they were mostly built to provide oil pan clearance for Drag cars back in the day....
The Early cars of the 60's, 70's and some of the 80's where bad enough, but to be messing with the steering geometry. You are going to be making a change where Bump/Roll Steer will be impacted.. If you have not heard what this is about, I suggest you try researching.
For a A-body, B-Body spindles and short upper A-Arms were one conversion the help eliminated positive Camber while going around a turn. But the Steering arm changed the geometry and does add some Bump Steer, but many (as I have done this convertsion) find the added value of eliminating Positive Camber out weights the small bit of added bump steer.
When you drop/lower your car with wtih springs or drop spindle.. you do cause some impact to the Steering geometry. For straight line racing, this may not be so much of an issue. But for a street or road/Auto-x racer.... this is important to be getting your steering geometry correct. Getting a correctly designed drop spindle is a plus (steering arm location). But them short A-Arms are a problem that caused positive camber while going around a turn under load.
Just something to consider...
If you get a "good" dropped spindle, your steering geometry should not change at all! If you mod the center link in any way that puts the tie rod ends in a different position, you are altering the geometry which will most likely have undesirable effects. The tie rod ends are where they are for a reason [the best GM could do back in those days]. But, as Bczee suggests, it is up to you if you are willing to trade one effect for another.
Rob
Rob
