ID LQ4 from vin or casting numbers
Old Sep 25, 2009 | 08:24 PM
jetback73nova's Avatar
Default ID LQ4 from vin or casting numbers
I am going to look at truck that has an LQ4 for my swap tomorrow. is there any way to make sure it is a 6.0? the truck is complete (although totaled).
if anyone has any other advice, as to things to check, that would be appreciated.
thanks
Old Sep 25, 2009 | 09:26 PM
Slow 346's Avatar
The motor should be stamped 6.0 on the back of the block. Most normal 1500 series trucks had the LQ4. I know the Denali had the LQ9. The LQ4s had dished pistons and the LQ9s had flat tops for more compression.
Old Sep 26, 2009 | 10:33 AM
Old Geezer's Avatar
The stock head gaskets have a tab that's stamped 6.0... Might look there. Also, look at the emission info, if you can find it. Should tell you something.
What yr and model of truck is it?
Old Sep 26, 2009 | 11:51 AM
it a 2002 truck, supposedly with a 6.0, that's all i know. i did some searching and found out that the 8th VIN character designates the engine and U=LQ4. I will also see if the heads are 317's. the engine is in the truck so my inspection will be limited.
Old Sep 26, 2009 | 07:40 PM
mach.80's Avatar
There will also be a 6.0 behind the power steering assembly if I remember correctly.
Old Sep 26, 2009 | 10:19 PM
bowtiecb's Avatar
i been searching wrecked trucks also, and as far as i can see, u is the vin# for the lq4. t,z,w was 5.3. dont quote im no expert just what i found thru searchn
Old Sep 28, 2009 | 09:41 PM
carrsls1_camaro's Avatar
First things first you could not get a 6.0l in a none SS 1500 truck. Second thing all none SS truck engines were LQ4's as the LQ9 can only be found in Cadillacs and Denalis.
Old Sep 28, 2009 | 09:52 PM
cutlass_455's Avatar
Drivers side, just down from the deck.
Attached Thumbnails ID LQ4 from vin or casting numbers-img_0341-2.jpg   ID LQ4 from vin or casting numbers-img_0342-3.jpg
Old Sep 29, 2009 | 12:13 PM
Jeff Smith's Avatar
Finally, I was looking for ID vin on LQ9.
What vehicle use the 799 heads?
Thanks for inform.
Old Sep 29, 2009 | 12:53 PM
Jeff Smith's Avatar
Default Helpful ID on LQ9
ID:LQ9 from Vin/Cast#
http://en.wikipedia.org/wiki/GM_LS_engine
Thanks
Jeff
Old Oct 8, 2009 | 03:27 PM
Jeff Smith's Avatar
I found excellent inform on castings#..Common-Question on Head Casting #s
